PostPosted: Wed Jan 04, 2017 3:09 pm
8.15 BETA010 (release candidate!):
Windows stand alone: http://www.stereotool.com/download/ster ... 15-010.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 15-010.exe
VST: http://www.stereotool.com/download/vst_ ... 15-010.dll
Windows stand alone 64: http://www.stereotool.com/download/ster ... 15-010.exe
VST 64: http://www.stereotool.com/download/vst_ ... 15-010.dll
Perfect Declipper plugin:
DSP: http://www.stereotool.com/download/dsp_ ... er_300.exe
VST 32: http://www.stereotool.com/download/vst_ ... er_300.dll
VST 64: http://www.stereotool.com/download/vst_ ... 64_300.dll
Linux 32 bit:
Command line 32 bit: http://www.stereotool.com/download/ster ... ETA815-010
GUI 32 bit: http://www.stereotool.com/download/ster ... ETA815-010
Linux 64 bit:
Command line 64 bit: http://www.stereotool.com/download/ster ... ETA815-010
GUI 64 bit: http://www.stereotool.com/download/ster ... ETA815-010
- Linux: Older kernel (14.4), new GCC (6.3.1). Improves compatibility with older kernels and performance!
- Changed scale of many sliders, dB scale sliders are now 'flat' over the whole range.
- MicroMPX Pi 2 old GCC warnings and compare performance!
- Declipper VST plugin (previous beta) crashes on parameter load
- Whitelist Allow * as in 192.168.*.* instead of /16 (Leifs formatting), and always allow 127.0.0.1
- Polish station with sound card issues. Appears fixed, wait a bit more...
- Bojcha's volume jump on switching presets - reduced
- Use Leif's 'run as a service' trick Works, more testing needed. -i creates link in ProgramData, -u removes it, any start checks it.
- Matt Levin: I was noticing the veil jumping around all over the place last night and remembered the fix was to turn the dehummer on and analyze the audio with silence and then leave it on and it fixed it and sure enough that was the case still
- SST web interface code compiles separate from SST now.
- Crash reported by Camclone
- Made code compile for 9sg again
- CPU load of I/O and processing framework reduced.
- Run as a service was broken in previous beta, fixed
- Hovering over tray icon now shows version number
- SST: Make IP/PORT changable without web gui
- SST: Settings were stored under stereo_tool.ini instead of OmniaSST.ini
- SST: Added importing Stereo Tool presets
- MicroMPX: Buffer underruns seen on ARM version, caused by logging/tracing library.
- Matt Levin: Annoying crackle in MB band 1 with higher lowpass filter frequency in Sound settings. Only seen on 1 test system, probably a sound card issue. Although it's still weird that he says it doesn't happen in 8.00. Ignoring this unless there's more info coming.
- SST: Preset list was empty on first start
- SST: Multiple MicroMPX output IP addresses and ports CN.
- SST: Launch browser automatically on first start.
- SST: Improved startup screen.
- SST: Currently active presets highlighted
- SST: Prepared for longer list of MicroMPX IP/ports (partially there)
- SST: Clicking on meters in top bar takes you to the page directly
- SST: Top bar meter that corresponds with active screen is highlighted.
- MicroMPX decoder: Shows more startup info and waits for pressing ENTER at end (since it's command line, better if someone clicks on it)
- MicroMPX decoder: Improved handling of out-of-order and lost packets.
- Run as a service added to stand alone version, including different crash restart behavior (just closes if service)
- Catch crashes (should include VLC crashes!)
- Added crash module to error message on crash - often it's a driver.
- Moved reading RDS from file to a separate thread, should avoid hiccups when reading from network drives.
- Bug fix: FM test tones were broken when using Ignore high frequencies (introduced in 8.12).
- Bug fix: VST plugin no longer cuts off the start of songs (bug introduced in 8.14)
- Bug fix: UECP port was always used (even if FM disabled).
- Bug fix: Potential bug in the non-ASIO sound card code that could cause crashes depending on some compiler optimizations (it never caused any problems. But it could!).
- Rewrote error logging code (todo: log to the proper directory).
- Improved something in the compressors to avoid a possible crackle when used in multiband mode with steep filters. Doesn't seem to actually happen though.
- ControlsPanel Destruct() not called when quickly stopping service - Never mind (cannot happen normally, the service version never starts ControlsPanel, test code only)
- Crash in 8.14 DSP - only 1 report so far, without any further info, ignoring for now.
- Add glowing yellow line around SST tray icon, to make it more visible.
- WatchCat reset, test that output level is 100%
- WatchCat license dingen.
- WatchCat font size
- SST: Reset settings when loading a new preset, now it keeps the current settings - that's bad for new settings!
- Stereo Tool: Add info to .sts files to allow importing them in Omnia SST.
- SST: Skype call with Jim about names. Processing done (mostly)
- SST: Improved Stereo Tool settings import
- Make FF and 100% FB^2 behave the same in speeds.
- Perfect Declipper crash
- UECP recv hangs after connection close - web server too??? When do I disconnect? http://tldp.org/HOWTO/TCP-Keepalive-HOWTO/overview.html -> Moved things to a separate thread, and if a new connection comes in the old one gets closed, instead of waiting for it infinitely and ignoring the new one.
- Someone reported that their ASIO card isn't visible in 8.20. It's there in 8.14. Digigram VX222v2. Maybe 32 vs 64 bit issue? -> Looks like it, it works in 32 bit Stereo Tool 8.20.
- Figure out way to show ms values in sliders with negative direction Wait for feedback, maybe in Hz or / in front of it?
- Attack Multiplier: Remove the x values? Maybe 0 in center, -10 to +10? (* and / would make more sense!) Wait for feedback, maybe switch x and /
- Make Pi image + script
- Build version with only FB^2 mode, without insane CPU load
- BS412 bug: Compressor was done AFTER BS412!! That was wrong and caused all kinds of weird issues. WARNING: Behavior of existing presets might change!!!
- Wait for FB^2 feedback
- Encrypted license
- SST interface in uMPX command line version
- Spoedcursus audio
- Framework Radboud
- Opdrachtdefinitie - wat precies willen we
- Turn #define TRY_WK off!!!
- Entering license in Mac version VST crashes
- WatchCat close issue on Mac
- Shane's Lynx card analysis.
- SST: More beta testers
- Thread priority overview
- SST icon must look like SST until there are meters.
- SST: Disable 'MULTICORE' for latency 128, maybe also 256. (What about LQLL?)
- SST: Multiple MicroMPX output IP addresses and ports in web GUI!!!
- MicroMPX: Improve pilot merge after drop when using slightly wrong frequency. (How important is this?)
- MicroMPX: Check Stokkemask compliance on drops
- Continue with AA Ratio, ARS Mode, Max Ratio, check which are needed and adjust GUI to make everything fit again.
- Check if FEEDBACK^2 needs to be added again anyway, Edwin van der Plank said it should...
- Add buffer underrun warning - auto detect lowest possible latency??
- Maybe add common logging?
- "Stuck" 1 dB difference multiband compressor mode before AGC
- SST: Change something with saving presets/loading presets so you can't accidentally load sound card settings etc. (DANGEROUS, can take you off the air!) "In a processing preset menu, you probably should only load processing files. Other omnia's have separate I/O presets. EVERYTHING is dangerous. HIDE it when in PROCESSING/CLEANUP. Save and recall system stuff separately?"
- SST: Help with ? in top menu which makes things clickable.
- SST: Add built-in help
- Weird volume issue - Doesn't reproduce anymore. I had a few times that I selected a preset, and suddenly the volume would be too loud so it would sound really bad due to horrible clipping. I also saw a NAN warning on screen when that happened. Haven't been able to reproduce it since, it could be something that has been here for years and almost nevre happens... but I'm not certain if that's the case. --> Not seen anymore.
PostPosted: Thu Jan 05, 2017 8:48 pm
^Beta 10 Perfect Declipper download missing. ;)
PostPosted: Mon Jan 09, 2017 9:42 pm
Sorry - links are updated now. If they work fine I'll upload them to the Perfect Declipper website.
PostPosted: Tue Jan 10, 2017 1:11 am
No prob, and thanks! :)
The DSP is working fine here for general local listening use after manual configuration.
Some issues to note:
1. Is the the clipper working? I do not see much waveform difference enabled or disabled. Even when enabled, there are still some spikes to 100%. The clipper meter in previous Perfect Declipper versions to verify action is missing, too.
2. The threads slider in the CPU settings blows out its table. Perhaps move down a row.
3. None of the installer provided presets appear to load. Installer preset file(s) or similar missing, perhaps? Could be related to issue #4 below.
4. There is an exception when trying to do a factory reset for all settings or attempting to load a recent preset file from the present dropdown menu.
PostPosted: Tue Jan 10, 2017 10:39 am
Hi, I just fixed issues 2-4, the clipper was indeed working. Sorry, I just tried if the software worked (and it did) and I thought that was it (I was mainly working on Stereo Tool and SST). So, I never noticed those crashes when loading or resetting. And yes, those crashes were preventing preset loads to finish. Turns out that during the reset, I was explicitly calling an internal reset for the multiband compressors (which don't exist) - that caused the crash.
I'll run a new build soon. (Probably in 2 hours during our lunch break).
PostPosted: Tue Jan 10, 2017 3:00 pm
Just re-uploaded it. Bugs should be gone now.
PostPosted: Tue Jan 10, 2017 9:22 pm
This still considered 8.20?
PostPosted: Tue Jan 10, 2017 9:49 pm
Sorry, that was only about WatchCat!
PostPosted: Wed Jan 11, 2017 11:06 pm
Thanks for the update and verification of the clipper properly working.
The only error I have found remaining is an exception when loading a recent personal preset file from the preset dropdown menu. I just noticed it is a different exception value than my previous post, so I am attaching the screenshot.
Once that exception is resolved, it appears Perfect Declipper 3.00 should be ready for mainstream release. :)
PostPosted: Sat Jan 14, 2017 11:42 am
Hi.
This error appears:
Pretty Girls in your city
