Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 1209 210 211 212 213 Next
PostPosted: Sun Oct 23, 2011 8:20 pm
@achez: You can just copy the text and paste it in a PM. Or mail me...
I sent you email.
And I now trying beta 132... It has be a Test or Joke? :shock:
http://www.abload.de/img/declipper50rm.png ...I going back to beta 131. Beeps and pop-up in beta 132 works ok :-D
PostPosted: Sun Oct 23, 2011 8:51 pm
I sent you email.
Hi Achez,
I saw your email, will update the preset - and fix the stand alone issue - tonight.
What do you mean by test or joke? It looks like it should (and you'll get the popup only once). So why are you going back to 131??????
PostPosted: Sun Oct 23, 2011 8:58 pm
I guess he responded that way because Unregistered shows up even for people that have registered.
PostPosted: Sun Oct 23, 2011 9:03 pm
Because I can using DeClipper. :-D
eldoradofm: ;)
PostPosted: Sun Oct 23, 2011 10:53 pm
hi
the beta 132 is strange
in standalone version the task is ok but nothing appears to screen ????
use Win 7 - 64b on 2 pc for test it is the same
what happend ?
PostPosted: Sun Oct 23, 2011 10:57 pm
Will be fixed.
PostPosted: Sun Oct 23, 2011 11:27 pm
Yeah we know will be fixed ... only for protocol in WIN XP stand alone version sometimes is starting two instances .. don`t know why!?
PostPosted: Sun Oct 23, 2011 11:44 pm
i stand with beta 131
i wait for Beta 133 or 6.20 release !
The new french radio open in 3 days !
www.declicradio.fr powered by stereotool !
PostPosted: Mon Oct 24, 2011 12:46 am
Exactly. I have the same problem with beta 132 (VST version). Going back to beta 131 solves it.
PostPosted: Mon Oct 24, 2011 3:47 am
BETA133 RELEASE CANDIDATE:
- Updated all the presets (removed copying errors, reorganized them, updated to latest versions)
- Stand alone version has a main window again
- Removed the declipper window warning if you have a registered version - for now (*).
(*) When I release version 6.20, the declipper will be a separate option that you can buy. Everyone who bought Stereo Tool in 2011 (that's roughly the time when I started working on the declipper, so if you've bought Stereo Tool since then you might have expected it to be included) will automatically receive a new key that unlocks the declipper, and so will everyone who participated in this thread if they already have a license (but since I don't know who you are you'll need to send me a PM or email with your name or email + forum user name so I can look up your current key and upgrade it). Others can upgrade at a reduced price.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-133.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-133.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-133.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-133.dll
Command line version: http://www.stereotool.com/download/ster ... 20-133.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-133 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-133 NOT AVAILABLE
- Fix Punch
- Fix crash at program close
- Reduce Loudness CPU load
- Scopes black background?
- Add AGC start level
- Save bandpass filter order
- Fix Loudness display
- Smarter lows volume drop against highs protection: First clip using reduced highs (highs protection filter), then do it again but do NOT lower the lows below the level found in the 1st step. - NO! No longer needed.
- Optimize clipper code: Reflection, smaller overlap (stronger reflection possible?); optimize RMS search filter; optimize voice vibration removal
- HPF bad since BETA080, especially with declipper enabled
- Highs vs bass distortion protection: Fix window edges.
- Add highs distortion sensitivity slider(s)?
- AGC hangups
- DC caused by clipper
- Fix pre-ringing artifacts
- Checkbox to combine bands 1+2 of Multiband
- Phase linear highpass filter if non-phase-linear is selected to avoid DC offset.
- Strict bass clipping
- Channel swap in normal output: ASIO enabled and Use multiple CPU cores enabled - see viewtopic.php?f=14&t=3065&start=1861
- RDS: Filter out trailing spaces in word wrap mode
- Protection for vocals (Dutch pirate music)
- Remove or simplify 'Advanced highs protection', look at other protection mechanisms. Use smaller measurement intervals - allows lower 'maximum drop' values (hence has less impact on 'good' highs) and will catch more problematic transients. Add masking to ignore very brief drops.
- Save new clipper, bandpass, multiband options (STS+VST)
- Extra HPF step either just before Singleband or - if that's not used - after the bass protections for Loudness. Maybe also for phase linear HPF!
- Robot effect when changing to lower latency. Caused by Phase Rotation at lower Quality settings.
- Add Declipper display in main window
- Save Declipper view settings.
- Weird frequency boost in Dirty Mids with pink noise.
- Update presets? (BASS_AGC etc.)
- Add declipper registration flag
- Change version number
- Check performance, especially of Multiband.
- Release 1 hour
- Look into Kernel Streaming, maybe using PortAudio
- Update voice vibrations filter: Flat response for adjacent bands! (And maybe only 2 or 3 or so)
- Add composite clipper
- Hiss in low latency output from high frequency content due to no lowpass filter - NOT NEW, and will be solved by redesign anyway.
- Ability to output 2 different MPX signals on 1 sound card (left and right channel), using 1 Juli@ for 2 signals. (cheaper)
