Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 492 posts ]  Go to page Previous 120 21 22 23 2450 Next
PostPosted: Thu Aug 11, 2022 11:10 pm
I don't know if it has been commented. How can I now use the web interface to load .sts files? On the old interface, any screen reader saw the load all and load audio buttons.
PostPosted: Thu Aug 11, 2022 11:37 pm
We're working on converting the new native GUI to the new parameter load/save mechanism. Once that's done it will come back. For now, it's indeed not there.
PostPosted: Fri Aug 12, 2022 6:47 pm
Playing with ST Enterprise. Great product for the multi-processing use on same computer.
Noticed that instance names are not saved correctly. When trying to type to the 'name' -field and press enter/tab the field goes empty again. When trying to write these names to straight to ini, those disappears when starting the Enterprise.
Also when I have some preset with several uMPX destinations set. And change the preset for example from Hello NINE to Moose Hot FM I loose my uMPX destinations except the first one. So I have to type the other ones again. And on some other scenario I got a tenths of empty uMPX destination lines with empty IP and all disabled. But the list was long :)
BR,
Janne
PostPosted: Mon Aug 15, 2022 7:11 pm
Confirmed. You can type them under Application Settings -> Preferences -> Title bar info, and that appears to work (including the saving). I'll look into that tomorrow.
Edit: Today, issue solved. 2 things were done in the wrong order, which caused the Application->Title to overwrite the instance names regardless of whether anything was being changed.
BR,
Janne
Confirmed. I'll look into it tomorrow, this one might be a bit more complex.
Edit #2: I think this one is fixed as well. There was a call that was hard-setting the size to 1 on any loads or resets...
PostPosted: Wed Aug 17, 2022 11:17 am
Any news on new I/O ?
PostPosted: Wed Aug 17, 2022 11:21 am
Any news ion new I/O ?
Switching the I/O over to the new mechanism for all products is risky, since there might still be bugs in it. So I only want to do that once we have sufficient feedback about it. Certain things (such as streaming input) were only added in the last weeks and work differently in the new I/O layer, and I am not yet sure if that doesn't cause issues. We need to make sure that it doesn't before we can switch everything (and by doing so, everyone!) over.
PostPosted: Wed Aug 17, 2022 12:12 pm
ok, just to say i still use 32bit Enterprise 9.84beta27 and since february - zero problems. Both input 1 and 2 in use + Asio on FM output.
Actually there is one problem, since there is no samplerate converter and easily can be problems with input 2 (in this case) and external player, since 192kHz must be used, while player is at 44.1.
PostPosted: Wed Aug 17, 2022 4:25 pm
Holding ctrl then holding the left mouse button on a slider makes the cursor disappear until the next app restart. Win10 x64 b35 and STE b40.
Also I notice in STEnterprise's IO, there's a slight delay on one of the outputs (I can't tell in which direction) between Normal and FM that doesn't seem to be there in the regular IO. Maybe a phase inversion? It's very audible when I use my headphones and speakers at the same time.
PostPosted: Thu Aug 18, 2022 7:46 am
When I use streaming output with metadata the stream buffer in every song change, and the start of the very song is lost. It’s imposible stream with metadata.
https://fmfeeling.com
PostPosted: Thu Aug 18, 2022 1:26 pm
I don't see the mouse issue (testing with BETA042, which I will upload in a moment). The outputs aren't perfectly in sync, but they don't need to have been in sync with the old I/O layer either. The old I/O layer often had a larger offset from the center than the new one if the buffer size is small.
