Post new topic  Reply to topic  [ 257 posts ]  Go to page Previous 120 21 22 23 2426 Next
PostPosted: Thu Oct 06, 2022 8:11 pm
I've just tried it here (both going to different pages and closing/re-opening) and I don't see it here. And there's nothing in the code that should do this (it should make Microsoft Sound Mapper the default, but afterwards it shouldn't touch it anymore - so if there's a bug in the code I can somewhat imagine that it would act up on restarts, but definitely not on going to another page and coming back.
Do you have the web interface open, or anything else that might be non-standard?
I am using the web interface to change things as i use a screen reader and the web interface is the only way i can operate the program currently.
PostPosted: Thu Oct 06, 2022 11:20 pm
Oh! I didn't realize that. I just found a bug that caused some pages (among others the input settings page) to stop sending changes back to the software. That was in the old web interface - are you using the old or the new web interface? I just solved that issue in the old web interface, so please let me know if the next build (building now) works.
PostPosted: Fri Oct 07, 2022 12:08 am
It's the old web interface, that is coming up for me by default using the versions from this thread.
PostPosted: Fri Oct 07, 2022 3:31 pm
Enterprise 066 win10x64 won't launch. 065 does. Should I send my ini?
PostPosted: Fri Oct 07, 2022 3:42 pm
Confirmed - it doesn't start here either. Looking into it now.
PostPosted: Fri Oct 07, 2022 3:47 pm
Found it. I had removed the "Turn unlicensed features off" from this build (since that's quite useless if there's only a single thing that can be licensed), but I also tried to hide it - which failed because it didn't exist.
PostPosted: Fri Oct 07, 2022 8:11 pm
I can confirm that the input issue is now sorted. Thank you.
PostPosted: Sat Oct 08, 2022 9:37 am
BETA067 is posted. Fixes some old and new web interface issues (entering texts failed).
PostPosted: Sat Oct 08, 2022 1:34 pm
So where we put address?
PostPosted: Sat Oct 08, 2022 2:11 pm
I had to clear out all other recent ST DSP plugins to keep Winamp from crashing for 067 :roll: but seems to be running fine :mrgreen:
