Post new topic  Reply to topic  [ 982 posts ]  Go to page Previous 120 21 22 23 2499 Next
PostPosted: Wed Sep 29, 2010 12:54 am
hans, do you mind if i email you my preset settings and check them?
Actually I tried posting (describing) mine here to get some feedback :-)
PostPosted: Wed Sep 29, 2010 12:55 am
So this means that if i reduce the LOW or the Highs more on Loudness i will have more room to all sound and high as well?
If you reduce the LOWs you'll usually hear the reduced bass immediately. Or the extra bass if you increase it. That's because the bass level is usually pretty constant, and very high.
i dont mind to reduce bass if i can use BassBooster... can i ?
If you reduce the HIGHs it usually only affects REALLY loud tones, mostly 'S' sounds. That's hardly noticeable, and doesn't affect most of the sound. (With the mentioned settings I'm getting extremely close to the Orban frequency content, despite the -16000). I beleive that StereoTool can produce better sound than Orban, am i right?
Also, for lower Loudness settings, these sliders have (nearly) no effect.
PostPosted: Wed Sep 29, 2010 1:00 am
I am trying yours.... as you mentioned...
I notice that with 3band AGC the sound, sounds better...
One more thing i noticed is that, where the track has more Vocals (mids) this setting make the voice sound very loud...
this i noticed so far i am listening...
ps.
sorry for my english.. :(
PostPosted: Wed Sep 29, 2010 1:03 am
I did some checks, and with these settings, if loud highs are present, ALL the sounds come out a bit softer in Stereo Tool than in the Orban. It's not a dramatic difference - 1-2 dB - but still it's there and it probably shouldn't be.
I'm not going to fix this before creating the 5.10 release, but I'll keep it in mind for future updates.
(It's probably as simple as boosting all the sounds when loud 'S' sounds are present - I'm already doing that but apparently not enough, or at least not if the highs are set this loud).
Except for these 'S' sounds, if I use headphones and play the Orban on one ear and Stereo Tool on the other, I cannot hear any difference (for the one track I've used for testing, that is - pressing MONO on my amplifier also doesn't make a difference). So these settings are really close. Tested using track 3. (There are some phase shift issues between the recordings, but I removed them with Stereo Tool before comparing the two versions).
PostPosted: Wed Sep 29, 2010 1:05 am
Could you describe 'better'?
Cleaner, more constant, less highs (but you already mentioned that you want more so that's probably not it), ...?
PostPosted: Wed Sep 29, 2010 1:11 am
I am on some special preset, like erlier "exp12"
I would like to know all bad things about preset
Please set post-amp to 1.00 and "keep band1 to band2" = 500
exp22.rar [2.59 KiB]
Downloaded 308 times
PostPosted: Wed Sep 29, 2010 1:13 am
Cleaner less lows on 2Band
less clean on vocals with better lows on 3band
PostPosted: Wed Sep 29, 2010 1:16 am
So.. 2Band on Agc sounds better.
I am trying -10000 on Loudness, in order to find the best Mids and Highs and then i will try BassBooster to boost bass cause is low..
PostPosted: Wed Sep 29, 2010 4:17 am
these are the changes i made.... i will check it out tommorow again.
I am trying to have CLEAN highs...
Extra loudness - Allow extra highs (advanced)=-15000
Extra loudness - Punchy=0.127499938
Extra loudness - Max Punch peak=0.870000005
Relative noise gate level - Band 1=10
Maximum volume - Band 1=28800
Maximum volume - Band 7=3640
Maximum volume - Band 8=1530
Above Top Limiter=0.25
Relative clip position - Band 5=1.816901207
Relative clip position - Band 6=1.631578922
Relative clip position - Band 7=1.500000238
Relative clip position - Band 8=1.409638405
Equalizer position - Band 3=0.941747665
Equalizer position - Band 4=0.960784316
Equalizer position - Band 5=0.960784316
Equalizer position - Band 6=1.325581312
Equalizer position - Band 7=1.43902421
Equalizer position - Band 8=1.43902421
Stereo Boost strength=6
Stereo Boost maximum amplification=4
Lowpass filter=15600
check it out... and let me know.
PostPosted: Wed Sep 29, 2010 9:42 pm
A few presets created with 5.10b19 and could be used for pop webradio:
Marino's Poppy -> nice for regular pop songs
Marino's Poppy-Soft -> nice for soft pop songs (Tracy Chapman, Crowded House)
Marino's Leveler -> sometimes you just need a leveler with a bit bass and stereo enhancement.
Enjoy!
5.10b19-Marino-29Sept10.zip [7.65 KiB]
Downloaded 315 times
