Here's an interim build of my HE-AAC settings using BETA3:
2ND AGC is enabled. Config:
3 Band
Target Output: 12.50 (-18.35 dB RMS)
Remove remaining peaks above: 150%
Gating level: OFF
Channel separation: 75% (12dB)
Up Speed: .00000/.00000 (Default)
Down Speed: .0003/.0003 (Default)
So far, so good. Very smooth. Here's the rest (and attached, for convenience):
Treble is reduced for HE-AAC. This all can be adjusted easily, and the dynamics will follow accordingly. For the most part, any radio station I've ever configured sounds pretty close to this. I like perceived dynamic range.
[Common]
Pre amplifier=5
Post amplifier=0.899999976
Extra loudness=1
Extra loudness - Allow extra highs (advanced)=0
Extra loudness - Punchy=0.284999967
Extra loudness - Max Punch peak=0.75
Extra loudness - Deep bass protection - Enabled=0
Extra loudness - Deep bass protection - Value=0.638750076
Bass protection - Enabled=1
Bass protection - Two steps=0
Bass protection - Clip level=140
Bass protection - Deep bass boost=0
Bass protection - Raise clip level if highs get above=150
Bass protection - Maximum clip level raise=35
Hard limit output=1
[Noise Gate]
Enabled=1
Difference=0
Noise level=3.849999905
Relative noise gate level - Band 4=1.150537491
Relative noise gate level - Band 5=1.352941036
Relative noise gate level - Band 6=1.409638405
Relative noise gate level - Band 7=1.150537491
[Singleband Compressor]
Enabled=1
Difference=0
Maximum volume=4
Attack speed=0.000001098
Decay speed=0.000763275
Above Top Limiter=0.199999988
[Pre Compressor]
Enabled=1
Difference=220
Delay enabled=0
Maximum volume - Band 1=22500
Attack speed - Band 1=0.000001125
Attack speed - Band 3=0.000001284
Decay speed - Band 1=0.0010933
Decay speed - Band 3=0.0010933
Dual band=1
Third band=1
Relative expected volume of highs=0.5
Relative maximum volume of highs=1.199999928
Relative maximum volume of very highs=0.149999991
Remove remaining peaks above (relative to maximum volume)=5
Maximum expected dynamics strength for smoothing=2
Enable smoothing=1
Smoothing time=12.529999733
Gating level=123201
Use ITU-BS.1770=0
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=5950
Maximum volume - Band 0=7250
Maximum volume - Band 1=7799.999511719
Maximum volume - Band 2=7500
Maximum volume - Band 3=6350
Maximum volume - Band 4=4200
Maximum volume - Band 5=3750
Maximum volume - Band 6=4650
Maximum volume - Band 7=3600
Maximum volume - Band 8=3350
Attack speeds linked=1
Attack speed - Band -1=0.000005229
Attack speed - Band 0=0.000005229
Attack speed - Band 1=0.000005229
Attack speed - Band 2=0.000005229
Attack speed - Band 3=0.000005229
Attack speed - Band 4=0.000005229
Attack speed - Band 5=0.000005229
Attack speed - Band 6=0.000005229
Attack speed - Band 7=0.000005229
Attack speed - Band 8=0.000005229
Decay speeds linked=1
Decay speed - Band -1=0.000089597
Decay speed - Band 0=0.000089597
Decay speed - Band 1=0.000089597
Decay speed - Band 2=0.000089597
Decay speed - Band 3=0.000089597
Decay speed - Band 4=0.000089597
Decay speed - Band 5=0.000089597
Decay speed - Band 6=0.000089597
Decay speed - Band 7=0.000089597
Decay speed - Band 8=0.000089597
Above Top Limiter=0.75
Clipping enabled=1
Postprocessing enabled=1
Relative clip position - Band -1=-1
Relative clip position - Band 0=-1
Relative clip position - Band 1=-1
Relative clip position - Band 2=-1
Relative clip position - Band 3=-1
Relative clip position - Band 4=-1
Relative clip position - Band 5=0.754385829
Relative clip position - Band 6=0.801801801
Relative clip position - Band 7=0.65289247
Relative clip position - Band 8=0.90476203
Final limiter value=1
Final limiter decay speed=0.999000013
Final limiter clipping=20
Equalizer enabled=0
Equalizer position - Band -1=1
Equalizer position - Band 0=1
Equalizer position - Band 1=1
Equalizer position - Band 2=1
Equalizer position - Band 3=1
Equalizer position - Band 4=1
Equalizer position - Band 5=1
Equalizer position - Band 6=1
Equalizer position - Band 7=1
Equalizer position - Band 8=1
[Stereo]
Enabled=3
Stereo AZIMUTH Enabled=1
Stereo Image Enabled=0
Stereo Boost Enabled=1
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=25
AZIMUTH change speed=0.199999988
Image phase amplifier=1
Image width amplifier=1
Extra phase shift=0
Mono or stereo only=0
Stereo Boost strength=10
Stereo Boost maximum amplification=0.799999952
Stereo Boost multiplier=0.899999976
Stereo Boost - Never reduce below original level=0
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=0
Lowpass filter=15000
Highpass filter=25
[Bass Boost]
Enabled=0
Strength=1
End lowpass frequency of input filter=250
Start lowpass frequency of output filter=250
End lowpass frequency of output filter=350
Clip level=1.5
Preserve louder peaks=1
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=3500
Start speed=1350
Number of rotations=6
Smoothness=0.985999942
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.5
Pre-limiter enabled=1
Pre-limiter relative volume=1
Reduced CPU processing=0
[FM Transmitter]
Enabled=0
Pre-emphasize=0
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/|\W"PLAYING %artist% - %title% "/1s:\T2h\:\T02m\:\T02s/1s:\T2h\:\T02m\.\T02s/1s:\T2h\:\T02m\:\T02s
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing - www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 - www.stereotool.com/30s:\W"%artist% - %title% - %album%"
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=1
RDS Music=1
RDS Artificial Head=0
RDS Compressed=1
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
[Direct soundcard access]
Enabled=0
Volume=1
Buffer size=1
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Volume=1
Buffer size=0.079999998
ASIO Override channel 1=2
ASIO Override channel 2=3
