| Site Admin |
BETA132:
- Updated unregistered version declipper behavior
- Fixed clipper bug reported by Bojcha (could cause certain frequencies to be played too loud, esp. when dirty mids/highs are used).
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-132.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-132.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-132.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-132.dll
Command line version: http://www.stereotool.com/download/ster ... 20-132.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-132 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-132 NOT AVAILABLE
- Fix Punch
- Loudness: Annoying cracking sound in bass. Slightly present in 5.00, worse in 6.00, maybe even worse in 6.10. Only when bass is too loud. Much worse than in Final Limiter (at same input level!) - so this clearly indicates a bug. Most likely cause: The filter that was added to remove bass artifacts....... - No, it's the louder bass. But it can be fixed by changing some settings. Default settings updated, and behavior for 'not Very strict' improved. Also Deep bass boost and Very deep bass protection are enabled for latency 512 now.
- Fix crash at program close
- Reduce Loudness CPU load
- Scopes black background?
- Add AGC start level
- Save bandpass filter order
- Fix Loudness display
- Smarter lows volume drop against highs protection: First clip using reduced highs (highs protection filter), then do it again but do NOT lower the lows below the level found in the 1st step. - NO! No longer needed.
- Optimize clipper code: Reflection, smaller overlap (stronger reflection possible?); optimize RMS search filter; optimize voice vibration removal
- HPF bad since BETA080, especially with declipper enabled
- Highs vs bass distortion protection: Fix window edges.
- Add highs distortion sensitivity slider(s)?
- AGC hangups
- DC caused by clipper
- Fix pre-ringing artifacts
- Checkbox to combine bands 1+2 of Multiband
- Phase linear highpass filter if non-phase-linear is selected to avoid DC offset.
- Strict bass clipping
- Channel swap in normal output: ASIO enabled and Use multiple CPU cores enabled - see viewtopic.php?f=14&t=3065&start=1861
- RDS: Filter out trailing spaces in word wrap mode
- Protection for vocals (Dutch pirate music)
- Remove or simplify 'Advanced highs protection', look at other protection mechanisms. Use smaller measurement intervals - allows lower 'maximum drop' values (hence has less impact on 'good' highs) and will catch more problematic transients. Add masking to ignore very brief drops.
- Save new clipper, bandpass, multiband options (STS+VST)
- Extra HPF step either just before Singleband or - if that's not used - after the bass protections for Loudness. Maybe also for phase linear HPF!
- Robot effect when changing to lower latency. Caused by Phase Rotation at lower Quality settings.
- Add Declipper display in main window
- Save Declipper view settings.
- Weird frequency boost in Dirty Mids with pink noise.
- Update presets? (BASS_AGC etc.)
- Add declipper registration flag
- Change version number
- Check performance, especially of Multiband.
- Release 1 hour
- Add composite clipper
- Hiss in low latency output from high frequency content due to no lowpass filter - NOT NEW, and will be solved by redesign anyway.
