Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 1207 208 209 210 211213 Next
PostPosted: Fri Oct 21, 2011 6:35 pm
(Man, I'm starting to answer that to almost every feature request...)
Might want to check the lenght of that 'to do' list.
You are the reason why they still need chain paper and a matrix printer :)
Maybe the input and outputs should be defined in another file like a config.ini. Not a really big deal but not so handy when creating presets and swapping machines and different configs every couple of weeks (yes, call me a nerd)
PostPosted: Fri Oct 21, 2011 9:47 pm
You are right... New idea is to do something like Breakaway: A setup phase where you can select (multiple!) sound cards for input and separate sound cards for normal and FM-output, and calibrate them. And then the rest.
PostPosted: Fri Oct 21, 2011 9:50 pm
Yes :D :D then i can finally just load a preset without calibrating all again and again.
PostPosted: Sat Oct 22, 2011 7:04 am
Actually... very little commercial printing is done on sheets. It's almost exclusively continuous feed. :o As far as a dot matrix, it's a little more advanced than that now.
Océ is sending 2 brand new prototypes to the shop I work at, we're the first to try them out... full color LED printing, plus spot gloss and a new invisible ink for bar codes and data matrices in partnership with a few dozen (so far) postal groups worldwide. Almost 3000 full color duplex A4 per minute. :lol: That's nearly 100 million pages per month if it's running 24/7. Not your daddy's dot matrix.
PostPosted: Sat Oct 22, 2011 8:20 am
And why not to save the output in the sts file . Imagine your computer is restarted due to electric shock. and when reload the ST which or who gonna told ST which interface to load .....? You may have 2 sound cards ... or virtual cables or else ..... I think that everyone (even when this sts is shared with someone else) selects the output and this will be saved for him ...if the output or input doesn`t exist it`s not a problem new one will be replaced in the sts. ... Nothing strange here !
PostPosted: Sat Oct 22, 2011 8:36 am
BETA131:
- Linux version is back!
- Updated Bojcha's preset after receiving new versions in a PM.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-131.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-131.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-131.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-131.dll
Command line version: http://www.stereotool.com/download/ster ... 20-131.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-131
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-131
- Fix Punch
- Fix crash at program close
- Reduce Loudness CPU load
- Scopes black background?
- Add AGC start level
- Save bandpass filter order
- Fix Loudness display
- Smarter lows volume drop against highs protection: First clip using reduced highs (highs protection filter), then do it again but do NOT lower the lows below the level found in the 1st step. - NO! No longer needed.
- Optimize clipper code: Reflection, smaller overlap (stronger reflection possible?); optimize RMS search filter; optimize voice vibration removal
- HPF bad since BETA080, especially with declipper enabled
- Highs vs bass distortion protection: Fix window edges.
- Add highs distortion sensitivity slider(s)?
- AGC hangups
- DC caused by clipper
- Fix pre-ringing artifacts
- Checkbox to combine bands 1+2 of Multiband
- Phase linear highpass filter if non-phase-linear is selected to avoid DC offset.
- Strict bass clipping
- Channel swap in normal output: ASIO enabled and Use multiple CPU cores enabled - see viewtopic.php?f=14&t=3065&start=1861
- RDS: Filter out trailing spaces in word wrap mode
- Protection for vocals (Dutch pirate music)
- Remove or simplify 'Advanced highs protection', look at other protection mechanisms. Use smaller measurement intervals - allows lower 'maximum drop' values (hence has less impact on 'good' highs) and will catch more problematic transients. Add masking to ignore very brief drops.
- Save new clipper, bandpass, multiband options (STS+VST)
- Extra HPF step either just before Singleband or - if that's not used - after the bass protections for Loudness. Maybe also for phase linear HPF!
- Robot effect when changing to lower latency. Caused by Phase Rotation at lower Quality settings.
- Add Declipper display in main window
- Save Declipper view settings.
- Check performance, especially of Multiband.
- Weird frequency boost in Dirty Mids with pink noise.
- Update presets? (BASS_AGC etc.) 1 day BUSY
- Release 1 hour
- Add composite clipper
- Hiss in low latency output from high frequency content due to no lowpass filter - NOT NEW, and will be solved by redesign anyway.
PostPosted: Sat Oct 22, 2011 9:09 am
I still have my Star nl 10, and it still works :-) No need to cut down complete forests for that printer. Oce should be ashamed actually.
PostPosted: Sat Oct 22, 2011 12:39 pm
Woeha! I still have my Canon T-22A MSX printer and it also still works. It prints on thermal paper :-) I even wrote a program years ago that allowed me to use it on a PC in DOS with WordPerfect :-)
To be honest, I don't even have another (newer) printer... No need to print anything.
PostPosted: Sat Oct 22, 2011 12:43 pm
Declipper licensing protection
The current behavior of the declipper in the unregistered version (a nagging voice every minute) is not really acceptable. My current idea is the following, please give feedback if you have a better idea:
If the declipper is not licensed, it is automatically switched off after one minute. A popup pops up (well that's what they do) telling the user that the declipper is disabled. And a short beep will be played.
This will happen both when a preset with declipper is selected and when the declipper is switched on manually.
Any suggestions?
PostPosted: Sat Oct 22, 2011 1:14 pm
Any suggestions?
Sounds fine Hans, it doesn't put anyone off and it is still protected from your side.
You might want to change the nagging voice for the rest of the processing. If you want to have a 'professional' voice let me know since I know a couple of people in that business ;-)
