Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 119 20 21 22 2359 Next
PostPosted: Tue Feb 23, 2016 12:14 pm
7.85 BETA036
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-036.exe
CHANGED:
Hi Hans
Exception crash in DSP version for B036...
Rossco
PostPosted: Tue Feb 23, 2016 4:59 pm
Ok I can *almost* see where this happens but not exactly yet. Because unfortunately I didn't store the 036 code base so I can't go back to it. So, I will just hope that the next version has the same issue, and I *will* make a copy of it this time.
On my pc, it doesn't crash btw. (And I think I know what I did, but not where)
Edit: I found some suspicious code. So, hopefully the next version is ok.
Note: The changes that are causing issues are some performance optimizations that seem to help on the Raspberry Pi. They have no effect on Windows with the Intel compiler, but of course I want to have the same code for both versions.
PostPosted: Tue Feb 23, 2016 10:58 pm
7.85 BETA037
Windows stand alone: http://www.stereotool.com/download/ster ... 85-037.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-037.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-037.dll
CHANGED:
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?)
- Exciter: Add auto-adjust HPF frequency
- Add Polar stereo viewtopic.php?f=16&t=6233&p=33031#p33031
- Put in Ben Liebrand settings for vinyl cleanup?
- Test "looper" optimization on Raspberry Pi 3
- Command line version doens't like long name (Antenne V. - see mail 2-3-2016 22:24).
- MP3?
LATER:
- O skin
PostPosted: Wed Feb 24, 2016 1:50 pm
7.85 BETA037
CHANGED:
Hans
Beta037 still causing exception. Checked both the DSP and stand alone versions - both are throwing the same error.
Rossco
PostPosted: Wed Feb 24, 2016 2:28 pm
Hello Hans,
Is there an Windows VST 64 bit Beat version?
Best regards,
Benny
PostPosted: Thu Feb 25, 2016 4:08 am
beta 34 VST was silent and would hang the audio path in Reaper. somewhere it got fixed because beta 37 VST works fine.
PostPosted: Thu Feb 25, 2016 12:40 pm
Hello Hans,
Best regards,
Benny
What is a Beat version? If you need 64 bit, for now you'll have to use the release version (7.84).
PostPosted: Thu Feb 25, 2016 12:42 pm
7.85 BETA037
CHANGED:
Hans
Rossco
I'm trying to find what's causing this, but it's problematic because I'm running into compiler bugs which makes it nearly impossible to debug the code and see what is happening exactly. Can you try this version and send me the error message again? That should help... Thanks!
http://www.stereotool.com/download/dsp_ ... 5-037A.exe
PostPosted: Fri Feb 26, 2016 6:12 am
I guess that was a typo and Benny meant a 'beta' version. :)
PostPosted: Fri Feb 26, 2016 9:08 am
7.85 BETA037
Hans - sill seeing Exception error in 37A.
What I have noticed -:
- Winamp will play audio (with sound unprocessed).
- Stereotool GUI is not active at all (no movement in console meters whatsoever).
- It will not show the exception error until you mouse over the GUI.
- Closing Winamp causes it to crash on exit.
Hope that helps in some way?
Rossco
