Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 345 posts ]  Go to page Previous 119 20 21 22 2335 Next
PostPosted: Mon Jul 27, 2015 1:28 pm
Ok, here is this
Video with clear difference that Advanced clipper causing all i`m talking about. I made output slider just how you tell me , even lower. No change . This is only for "over signal" issue . I can make one for jumping and spike to see it`s still there.
http://www81.zippyshare.com/v/pduRWTW2/file.html
Download it if not running from web.
That's the other issue, not the jumps! I think I've solved this one now too (next beta). So, the next beta shouldn't have either of these issues.
PostPosted: Mon Jul 27, 2015 1:30 pm
Stereo Tool 7.71 BETA017
Windows stand alone: http://www.stereotool.com/download/ster ... 71-017.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 71-017.exe
Windows 32 bit VST: http://www.stereotool.com/download/vst_ ... 71-017.dll
- Check new clipper highs
- Remove "Take some shortcuts" under CPU, probably broken! And has not much effect anyway. -> Hm, no, must have been in use for the tests. Ugh... TEST to check what is better: ON (which will probably allow more sounds through) or OFF. -> Actually it does seem to work AND allow more highs through, but I don't know if that's a good thing - more tests needed!
- Added lowpass filter after clipper in non-composite mode.
- Fixed problem with click sounds (reported by DJ_DOGGY). Reduced output level by 1% - you can safely increase modulation by 1% if you're using an output that's affected by this (should only be FM signal inside a plugin). If you're using the stand alone version, make sure to set the output level to the sound card no higher than 99% (-0.1 dB).
- Fix downsampling and Quality slider problems: Lower Quality setting
- Attempt to reduce effect on volume of using Leif's clipping method.
- Fix DJ Doggy's reported errors (19 kHz, junk around tones).
- Ignore frequencies above a specific frequency -> Should lower TOTAL CPU load by another 10-20% (now fully implemented except at lower Quality settings)
- Fixed the lowpass bug that was introduced in 009. Although it has probably always been there! As a side effect, the output is also slightly louder (about 0.02 dB) with no negative effects.
- Fixed distortion introduced in 009/010. Extra highs are still there though! See new 'Sparkling highs' section under Advanced Clipper -> Sound
- Fix optimizations
- Fix code #warnings
- Some small optimizations
TO FIX 7.71:
- Make Chain block (small size) based - Partially done
- Synchronization is broken in 008 (was ok in 007) - Don't see it!
TO DO 7.71:
- VST multiple instances fails
- Make VST window bigger
- Add delay (in samples) for one of the two MPX channels to send audio to allow synchronization of 2 transmitters which use the same frequency. (John Markis)
- Noise learning Micha
- EQ with 'standard' sliders.
TO DO WITH LEIF:
- Clipper issues Leif / Wolf Stahl (probably the same thing) - Should be fixed now. - Waiting for reply Wolf
PostPosted: Mon Jul 27, 2015 1:52 pm
Hm, who reported that synchronization is broken and did work fine in beta007? I can't find it anymore, and synchronization seems to work fine here (I also tried beta008 and didn't see any problems there either).
PostPosted: Mon Jul 27, 2015 2:00 pm
Ok, here is this
Yes, it`s not for jumping - i mention it.
But let me test this last beta17 to see how is it.
PostPosted: Mon Jul 27, 2015 2:21 pm
tested for issues beta 17 .
:( All are there - video issue (but looks like a bit small and i guess it`s from the non-composite filter , not from Clipper itself) . Jumping noise floor too. Spike from "Ignore" is there too.
I see when Advanced clipper is enabled - L-R signal is filled with some spikes . Input signal is 0 degrees phase and if i turn Advnaced clipper off , this fill is gone. May be it`s a phase issue?! I don`t know what to think any more... If needed a video , i`m here to do it.
PostPosted: Mon Jul 27, 2015 2:28 pm
I see when Advanced clipper is enabled - L-R signal is filled with some spikes . Input signal is 0 degrees phase and if i turn Advnaced clipper off , this fill is gone. May be it`s a phase issue?! If needed a video , i`m here to do it.
Now I'm confused.
Isn't "Jumping noise floor" and "Spike from 'Ignore'" the same thing? I'm not seeing it here at all anymore (and I did before). Also I ran a track through versions 7.70 and 7.71-017 and the spectrum looks nearly identical (7.71-017 is again slightly louder). Both with composite clipper and with standard clipper.
PostPosted: Mon Jul 27, 2015 2:32 pm
No Hans,
Spike from ignore is a single frequency that moves by moving the slider .
But jumping floor is the whole frequency band for MPX jumping ( i mean only noise floor)
Without signal is jumping too..
Here are some joker : Without input signal , spike from Ignore issue is not there , only noise floor is jumping.
When apply input signal , spike appears additionally!
The only good news is that MPX power indicator is working again :)
PostPosted: Mon Jul 27, 2015 2:34 pm
Yes everything is ok now. The clipper has the old filter response and there are no hiccups when using "ignore high freq". The is a problem though. If the ignore high freq's frequency is set near the 19khz pilot it "distorts" the pilot.
My radio station
http://amradio.ddns.net
PostPosted: Mon Jul 27, 2015 2:36 pm
It distorts because there is a spike that you not see , but i am ! That is why i propose Hans to take some AMD and to test all my suggestions . I have 240e by Athlon II.
PostPosted: Mon Jul 27, 2015 2:40 pm
It diostorts because there is a spike that you not see , but i am ! That is why i propose Hans to take some AMD and to test all my suggestions . I have 240e by Athlon II
Correct i can see it now .. I have it set to 16khz and low pass filter is set to 15khz and there is an a tone in 16khz
My radio station
