Post new topic  Reply to topic  [ 982 posts ]  Go to page Previous 119 20 21 22 2399 Next
PostPosted: Tue Sep 28, 2010 11:32 pm
hans, do you mind if i email you my preset settings and check them?
PostPosted: Tue Sep 28, 2010 11:55 pm
How big is the difference? And is it with the input volume set such that the bars stay close to the top? Because then I can explain it... If you increase the input volume, the output volume will be slightly higher too - the effect is the biggest when the volume is such that the AGC has little effect on the volume (= the bars stay near the top).
Difference is when bars are at mid and when i rise input bars are close to down ..
PostPosted: Wed Sep 29, 2010 12:06 am
That makes sense - at mid the effect is less - in other words, the output of the AGC is softer. This is (more or less) intended. It shouldn't be too bad anyway, it just stays a bit closer to the original. (This behavior hasn't changed since version 5.01 by the way)
PostPosted: Wed Sep 29, 2010 12:31 am
Reduce 'Allow louder highs' to -16000 ????? is this correct??? i want more highs......
PostPosted: Wed Sep 29, 2010 12:40 am
hello?????? do you see my posts??? :p
PostPosted: Wed Sep 29, 2010 12:43 am
You're already increasing the 3 top band sliders. That means that there's a lot of highs. The problem with this is that too much highs in Loudness causes a drop of all other frequencies, which sounds bad. Reducing 'Allow louder highs' SLIGHTLY reduces the peak levels, giving enough room to the rest of the sound. (Basically it's an extra de-esser for Loudness)
Of course you can experiment with the settings - I was just attempting to get close to the Orban sound (in frequency content that is), these settings (according to an analysis of a portion of sound) give you a sound that's within +/- 1 dB for the entire frequency range, with the same total RMS output level.
If people really want this amount of highs, I might need to re-tweak Loudness to be better able to handle it without volume drops on other frequencies.
PostPosted: Wed Sep 29, 2010 12:44 am
@ Chris
Welcome to this forum !
But:
This topic is for discussion , feedback :arrow: and bug finding of Beta versions.
So if you "want more highs" it is a question of personal taste.
Check what ?
If you want feedback and help for your own presets/settings than you can upload (share) your .sts preset files here and wait for reactions:
:arrow:
viewforum.php?f=10
PostPosted: Wed Sep 29, 2010 12:47 am
So this means that if i reduce the LOW or the Highs more on Loudness i will have more room to all sound and high as well?
PostPosted: Wed Sep 29, 2010 12:50 am
Nice meeting you Too... :) sorry i was off topic.! :)
PostPosted: Wed Sep 29, 2010 12:52 am
If you reduce the LOWs you'll usually hear the reduced bass immediately. Or the extra bass if you increase it. That's because the bass level is usually pretty constant, and very high.
If you reduce the HIGHs it usually only affects REALLY loud tones, mostly 'S' sounds. That's hardly noticeable, and doesn't affect most of the sound. (With the mentioned settings I'm getting extremely close to the Orban frequency content, despite the -16000).
Also, for lower Loudness settings, these sliders have (nearly) no effect.
