Post new topic  Reply to topic  [ 286 posts ]  Go to page Previous 119 20 21 22 2329 Next
PostPosted: Tue Jun 01, 2010 4:39 am
- it has 25us at output also.. Comrpessed ..mmmm now what ?
- With this two AGCs i have problem to UP input signal because it's already high. and some left/right waveing is occuring - 2nd agc
PostPosted: Tue Jun 01, 2010 10:42 am
Hm... Should I treat the signal as mono in the 2nd AGC? (That might make sense - it's set more aggressively so differences between left and right immediately lead to volume differences.)
PostPosted: Tue Jun 01, 2010 1:36 pm
sum mono or dual mono ...hm, some processors have mono control :idea:
PostPosted: Tue Jun 01, 2010 3:02 pm
Mono control?
I could add a slider to switch between full stereo (current situation) and full mono... Separate for both AGC's (assuming that I keep 2, but based on my own tests and your responses as well, I think I will, although I'll probably keep the 2nd one turned off by default)
PostPosted: Tue Jun 01, 2010 3:05 pm
if there is not lot of job we can try ...
Just .. not mono Audio .. just mono detecting.
PostPosted: Tue Jun 01, 2010 3:12 pm
LOL :-) Yes of course! That's what I meant :roll:
And should be very easy to add (just averaging the 2 RMS values - well, RMS averaging that is)
PostPosted: Tue Jun 01, 2010 3:49 pm
This is (as usual...) a bit more tricky than I expected.
I think that in case of mono processing, I need to calculate the minimum volume of the two channels, and then use that for both. Just taking the average level would lead to (assuming silence on one channel):
- Twice as loud sound on the other channel. More difficult for 'remove remaining peaks'.
- Multiband gets a twice as loud input on the channel with sound.
PostPosted: Tue Jun 01, 2010 3:57 pm
:shock:
Only 'mono' fileter in ST is Single band limiter/compressor? how you do that (?) :)
PostPosted: Tue Jun 01, 2010 11:04 pm
I am very clossee... (bass punch and voices)
ST5_EL34_3.rar [2.4 KiB]
Downloaded 340 times
load in:
http://www.stereotool.com/download/ster ... r_BETA.exe or
http://www.stereotool.com/download/dsp_ ... r_BETA.exe
PostPosted: Wed Jun 02, 2010 1:41 am
I've uploaded a new version where you can control the stereo separation - at 100% it's identical to the previous version, at 0% the two channels are identical in volume (except when the difference gets too big and 'remove remaining peaks' starts to kick in).
Note: This is an update of BETA2, not of BETA (Bojcha, I saw that you're still using BETA instead of BETA2... BETA2 _should_ be slightly _better_ than BETA!)
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... _BETA3.exe
Stand alone version: http://www.stereotool.com/download/ster ... _BETA3.exe
VST version: http://www.stereotool.com/download/vst_ ... _BETA3.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... _BETA3.dll
Command line version: http://www.stereotool.com/download/ster ... _BETA3.exe
Note: New sliders are NOT yet saved to disk!
Edit: Hm... When testing this version further, I think I could just as well set the first AGC default channel separation setting near 0%. IF it's needed, the 'remove remaining peaks' setting will cause one of the two channels to drop if - otherwise - peak removal would have to kick in.
Edit #2: I discovered a 'bug': If I play a beep and set 'remove remaining peaks' at 100%, no peak removal should happen - but it does (caused the the smoothing of the behavior at input level near target level). Will have to check what's wrong there.
