Post new topic  Reply to topic  [ 210 posts ]  Go to page Previous 117 18 19 20 21
PostPosted: Mon Sep 04, 2017 11:50 am
I don't see an M43 listed in https://www.cpubenchmark.net/cpu_list.php , is that really the exact model number?
Yes that's what windows lists it as, it's quite possibly this one? https://www.cpubenchmark.net/cpu_lookup ... GHz&id=775
PostPosted: Mon Sep 04, 2017 11:58 am
InPhase, not too sure who you are, Im guessing. The BCL406 are equipped with a blast furnace CPU (i7 4Ghz). I truly cannot see you even coming close to using even 40% of the available processing power for ST with everything turned flatout.
There are ways to back off the CPU use gentle without too much of a impact. However, as more features in ST come into play, then unfortunately you do need several cores and importantly, plain old clock grunt to get around and perform the mathematics thats been requested by the application.
Glenn @ CoastFM 96.3, thought you would've known from my previous shared settings posts?
That's good to know about the BCL406, because I'm going to push it hard as more of these good features come online.
PostPosted: Mon Sep 04, 2017 12:22 pm
Hey Glenn, thought so.
Just checked what I think is your CPU at home and its specs are not too flash. Only rates in around 2104 and is primarily due to its low clock speed. I have found that you need at least 2.6Ghz to run all 8.00 features, and now with the new AGC & Auto EQ, you may need more. Will need to test but Im away this week in PNG on another job.
Hopefully this answers your question on the home CPU.
https://www.cpubenchmark.net/cpu.php?cp ... 40+2.27GHz
PostPosted: Wed Sep 06, 2017 4:06 am
I got everything working beautifully again.
I put the windows version of Winamp on my Macbook Pro, which has heaps more cpu power, using Winebottler & finished off my new preset build that I'll post up soon.
The other computer is oldish, but still does what's needed (except processing ST now), so I'll do all my ST builds at home on the mac now.
I'm happy again & the beta 053 is working very well & sounding great.
PostPosted: Thu Sep 07, 2017 8:16 am
8.41 BETA058 - RELEASE CANDIDATE
Windows stand alone: https://www.stereotool.com/download/ste ... 41-058.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 41-058.exe
VST: https://www.stereotool.com/download/vst ... 41-058.dll
- Remove a bunch of presets
- 64 bit Pi build
- Update Wes' and Paul's preset
- 9 memory usage First bit done
- MAC build
- MicroMPX Linux: Directory reading logging
- MicroMPX: Add built-in help
- MicroMPX Pi 64 bit: Build warnings
- Mu character in SST
- MicroMPX: Log directory must end at .log, not .ini (Windows)
- SST: Green color for eq
- SST: Rename Auto EQ Koek
- SST Quality > 100% crash -> Again a compiler bug!
- SST: Ohio Valley and Blue Steel use Pre Amp
- Old web interface: Fix display of vu meters, also for SC
- Old web interface: Text color in check boxes and buttons doesn't update
- Weird RDS crash appears to be back. Now in SST. Still only in release mode.
- SST: Update help Done for now, more documentation for new stuff needed.
- Clipper was re-calculating pre-emphasis curves constantly when outputting both pre-emhpasized and separately processed audio.
- Linux version sometimes GUI doesn't open - retry internally?? -> Apparently a known bug, using the same workaround now that Chromium uses.
- Linux version doesn't exit.
- MicroMPX check feature 1 vs 2 (no error shown!)
- Check MicroMPX and Stereo Tool with Valgrind.
- Change version number
- Linux version crashes in latest Debian (Jack compatibility issue?) -> Not here. Will retest when new build is ready.
- .sbr file errors in generic_stereo_tool debug -> Deleting DEBUG folder fixed it - rebuild did not!
- Kill ProppFrexx logging!
- Integrated MicroMPX in something.
- Old web interface avoid reload OR pass GUID. Right now top presets list is flashing.
- Old web interface: Original right load can be messy. Load left first? -> No load logo page first
- Old web interface: Fix left display
- Old web interface: Don't set default selection.
- Wide display: Make meter section wider
- Fix build warnings
- Reported sound card buffer overruns pthompson -> Not fixed, Windows 10 update broken VAC driver.....
- SJP: Weird stuff at very low latencies with SJP levels, goes up and then down sometimes.
- Stereo Image was broken in BETA049
- Name "Spectrum Controller" -> Rename? DONE, now called Auto EQ
- FM Demodulator reported to be broken (must be the compiler switch again... grrr.... -> No, was caused by change in IPP!
- AM clipper is now always oversampled
- Allow moving equalizer between MB's
- Allow moving BB before last MB
- SST: Couple Hard Limit to clipper on/off
- SST: QoS dynamic DLL -> Werkt, maar QoS niet??
- SST: Network: Add "Interface" selection. Also priority?
- SST: Add Stereo Image phase filter - somewhere. Under AZIMUTH (rename it to Phase or something)
- SST: C-QUAM divide by 2 issue
- SST: Bass Boost: Relax limits on frequencies
- GUI doesn't work in some of the versions of 046
- Disable Pre Limiter display in limiting mode.
- Share PEQ, attack/release?
- Move Spectrum Control and new AGC out of "Experimental" tab, and allow licensing. --> Button to buy it will be added to the website on Monday!
- Show Spectrum Control and new AGC in bottom display
- Optimize limiter
- Allow using bass distortion in bass clipper when used for final limiter.
- Limiter display freeze
- Add pre-AGC classical music thing
- MicroMPX add display for packet reception todo add reset packets, fix timing, show current playing position
- Add "Advanced Dynamics" to license overview screen
- Finish pre-AGC classical music thing
- SST: Make list of new ID's
- 64 bit Hard Limit is working again
- Meter for Limiter is no longer frozen.
- 9sg - update to latest code
- Old web interface bug fixes
- 9sg 1 thread.
- Add bass clipper + final limiter for testing for streaming, to figure out once and for all if it's useful or not.
- Final limiter: Make speed depend on amount of bass clipping.
- Final limiter: Fix going though chunks.
- Spectrum Control: Abrupt Change Protection could overract because it ignored certain settings.
- Spectrum Control: ACP can overreact!
- Spectrum Control: Why is kick so fast?
- All compressors: Attack/release behavior in the new RMS mode was wrong, now fixed. Result is more consistent and movements are less sudden.
- Compressor inverse-Covfefe
- AM stereo downmixer 9
- Show backup input is active - change color of input level meters
- Final limiter: Put in separate file, so I can test it separately.
- Final limiter: Make own settings page. Lots of settings needed...
- Final limiter: Make it work for Quality != 100%, Latency != 4096
- MicroMPX web interface
- Fixed crash when changing number of bands in Spectrum Control.
- Add Parametric EQ to AGC 2
- RDS: 8 character words with <| go wrong
- RDS: Empty fields - remove?
New "Experimental" section, containing:
* NEW AGC
* New Spectrum Controller (replacement of Power Bass/Power Highs), adjusts the spectrum BEFORE the AGC, without affecting dynamics or loudness.
The Analog compressors now have new "Max ratio" and "Max ratio at" settings to have dynamic ratio's depending on how the amount of attenuation.
- Fix crash
- Check FB^2 ratio - Found fixed for NCME
- Make copy of Adjustment and only turn of if MAIN drops far enough. Should get rid of temporary rises (Abba)
- Fix "Shape" in new RMS mode (just square it?)
- Add Sudden Jump Protection (directly to compressor if possible)
- Fix Triple Normal Output separate processing clipping level if pre-emphasis for FM is disabled.
- SJP: Fix Attack speed (don't use weird Shape)
- SJP in SC mode broken in MULTICORE mode.
- AGC: Gate before Drive
- SJP: Compensate for window edge
- SJP: Remove dependence on latency setting (2048)
- SJP: Test at lower latencies: 4096, 2048, 1024, 512, 256, 128
- SJP: Better lookahead. NO. Good enough.
- AGC: Make lookahead depend on SJP on/off.
- Dynamic ratio: Weird behavior with 1.001:1 as start.
- ACP: Add On/Off in SC.
- SJP: Channel merging: Fix display
- Fix Max Ratio in GUI (break out in separate subpanel)
- SJP: Auto-calculate Level Boost
- SJP: Remove dynamic ratio and add asserts.
- SJP: Add support for ratio
- SJP: Auto-recover when close to target, so Level Boost is less critical -> Not needed I think?
- Test compressor behavior, compare with 8.40 and verify no changes
- Add licensing code (SC, Dynamic Ratio)
- SC ACP: Speeds should not affect it!
- Switched to a new compiler, slightly better performance (+3%)
- Improved NAN recovery handling and fixed 2 possible causes of NAN's
- Added maximum threshold to the compressor, it doesn't do anything if the input exceeds that level.
- Add new presets!
- NAB! LW!
SST/MicroMPX:
- MicroMPX web interface version: Make sure that all ranges are correct and everything is stable when changing settings. -> Mathijs & Matthijs - sent
- MicroMPX sample rate bug
- ProppFrexx reported crash Version with extra logging sent
- NAN? Doesn't reproduce, postpone for now
- WatchCat MAC installer.
- 9 memory usage
- New Stokkemask idea
- _CrtSetAllocHook(AllocHook);
- ladspa? r.co (Also AU & ProTools)
- Smarter stereo-to-mono conversion (only when needed). Use amount of reduction instead of maximum degrees!!!
- Optimize Spectrum Control and AGC 2
- Update RDS encoder to Mathijs' filter.
- ADYEN
- Growling bass (add to True Bass as post filter, compare with https://www.refusesoftware.com/lowender ).
- RDS: Make note in help about shared drives. Also send to Omnia.
- Try new stereo widener idea
- SST: Make it switch to backup input when the normal/FM signal switches.
- Make compressor with alternative ratio implementation
- Test clipping
- Improve UECP ASCII mode for Magic RDS (just handle \n's inside strings)
- RDS UCEP: Put a timeout on the fallback to default settings. Some programs close the connection immediately.
PostPosted: Thu Sep 07, 2017 5:44 pm
How about a Linux version to test before you release this?
PostPosted: Fri Sep 08, 2017 3:12 pm
For who needs a description of Auto EQ: https://www.stereotool.com/documentation/8.50/auto-eq/
PostPosted: Mon Sep 11, 2017 12:41 pm
Hans, whats the price for license upgrade for this Auto Eq ?
PostPosted: Mon Sep 11, 2017 1:02 pm
See https://www.stereotool.com/products/.
PostPosted: Tue Sep 12, 2017 10:08 am
8.51 BETA001
Turns out that, due to a bug in Microsofts latest Visual Studio, version 8.50 does NOT function properly in Windows XP! I have a new build that fixes that, and also reduces the memory usage a bit. I will run a release build as soon as the new MicroMPX is ready.
Windows stand alone: https://www.stereotool.com/download/ste ... 51-001.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 51-001.exe
VST: https://www.stereotool.com/download/vst ... 51-001.dll
- Reduced memory usage by calculating fewer window shapes
- XP build fix
SST/MicroMPX:
- 9 memory usage
- ADYEN
- Test clipping
