Post new topic  Reply to topic  [ 749 posts ]  Go to page Previous 1 2 3 4 575 Next
PostPosted: Fri Nov 06, 2009 2:22 am
Hi Bojcha,
That won't change - I'm only working on the Multiband / Pre Limiter / Noise Gate latency, but those artifacts are caused by Loudness.
Actually i was just trying multiband + hard limit (!?) .. nothing else
And in "low latency mode" there is strange "harmonics" (i think that is the word). i can hear more clear if i up first two sliders in EQ. With "post filter" there is more.
PostPosted: Fri Nov 06, 2009 10:05 am
Ok... In that case, they should be gone in the new version (there isn't even a 'post filter' anymore).
However, if I implement low latency clipping, it will return... :( (only if you enable it, of course)
PostPosted: Sat Nov 07, 2009 3:49 am
Hi Bojcha,
I've put something online for testing. Set it to Low Latency mode to test the new Low Latency processing.
Note #1: Pre-emphasis is currently NOT working, so this version is not really suitable for FM broadcasts. I'll try if I can create a 0-latency pre-emphasis tomorrow - if not I can definitely create one with a very small latency.
Note #2: There's a second input channel active now, please set it to an input that reads silence or you might get really strange effects. I first started with the low latency and silence detection stuff before I discovered that there may be better ways to reduce the latency...
Note #3: For some reason the multiband filter in low latency mode swaps the channels...
Note #4: If the difference with the default pre limiter/multiband settings gets bigger, the sound may differ more from that with low latency disabled... The multiband frequency response control is also a lot less precise because the separation between bands is very weak.
Note #5: Clipping and "limit output" currently don't work in low latency mode.
Command line: http://www.stereotool.com/download/ster ... d_BETA.exe CRASHES
Note-to-self: Create very-small-latency pre/de emphasis + lowpass filter by bypassing any low frequency filtering!
PostPosted: Sat Nov 07, 2009 11:01 am
This working very good.
I do quick test and make MIC preset with multiband/eq, noisegate, and simple compressor, sounds good and latency is still low.
one question, will meters work in multiband for lowlatency mode?
I found what causes strangde harmonics/chorus in lowlatency mode.. and it's not multiband .. it's bandpass filter.
PostPosted: Sat Nov 07, 2009 11:16 am
The meters will start working again. I'll try if I can fix the bandpass filter...
PostPosted: Sat Nov 07, 2009 5:51 pm
Here is my measurements:
multiband + noisegate + simplecompressor = 11ms , and that is fantastic.
But, That is without asio latency!
on 48kHz input, it's 38ms (asio only - ST bypass) + 11ms processing = 49ms
on 192kHz it's less but i can't measure because "monitor" on my e-mu 0202 not working 192kHz
Then i try breakaway live.
Interest is that only you can choose 44,1 or 48kHz for i/o. Processing + asio (overall) is 15-17ms.
so, what is it with ST asio ?
PostPosted: Sat Nov 07, 2009 8:36 pm
Hi Bojcha,
Previously, I had some filters that I had to process in blocks. Now, if a block is 15 ms, and the latency is less than 15 ms, I would run out of data.
That's why I filled in a minimum latency of 20 ms - and until now that wasn't too bad compared to the total latency. I'll lower it!
(By the way, 11 ms?! It should be less than 1... Will look into that)
I found a bug in the multiband processing --> will also fix that later tonight, fixing it should give better control over high frequencies.
And, Pre-emphasis is working now, also with a latency of 2 samples. The difference with the original pre-emphasis filter for frequencies below 14 kHz is less than 0.2 (50 us)/0.4 (75 us) dB! And de-emphasis should be possible with the same latency.
PostPosted: Sat Nov 07, 2009 9:11 pm
I measure simple...
reset .. i turned on multiband, noisegate, singleband compressor and hard limit... (hq on, lowlatency on and input 48kHz input)
I measured with bypass and without bypass... and one is 49ms and other 38ms.
So 11ms is for processing right?
Even better if this 11ms can be 1ms.
I am now more worry about why is more latency is with 48kHz and less with 192kHz.
PostPosted: Sat Nov 07, 2009 10:42 pm
I think I figured it out now.
In my stand-alone implementation I'm using the same "block size" (bunch of samples for which I call the processing) that Winamp uses: 1152 samples.
1152 / 44100 = 0.026 s = 26 ms
1152 / 192000 = 0.006 = 6 ms
I'll make a few quick changes to reduce the ASIO latency a lot more.
PostPosted: Sun Nov 08, 2009 12:32 am
Since I installed Vista64 my Juli@ ASIO support is completely broken. So I cannot test anything :-(
In about 1-2 hours I'll upload a version where I changed 2 things:
- Minimum ASIO latency setting can be set as low as 2 ms instead of 20.
- Processing blocks when using Low Latency mode are 64 samples instead of 1152.
But for now I really don't know if it will work or not.
