Post new topic  Reply to topic  [ 25 posts ]  Go to page Previous 1 2 3
 Post subject: Re: Which sound card?
PostPosted: Sun Apr 01, 2012 2:27 am
Hi..i am new here in this best forum and i have questions from interior of Brasil.
We have a litle FM station ,PC windows 7 , and use Brasilian automation program to put on air the FM station.
I have question about sound card 192 khz.
Please, answer me if is good the results when use sound card M-Audio 192.
Whath is preferible.. Maya 44 or M-Audio 192 khz ???
Here in my area dont have Julia@ . Thanks and congratulation for this best program and forum.
Luis- Batatais - Brasil
PostPosted: Mon Apr 02, 2012 2:00 am
i never tested M-Audio but i think that card knows to have big tilt. Also, i think there is some modification for that.
So, ESI Maya44 PCI will be better option.. However that soundcard is 96kHz on input!
PostPosted: Mon Apr 02, 2012 3:22 am
Ok Bojcha..
Abouth ESI Maya 44 PCI is a good card,but i need input 44.1 khz and out 192 khz to use with FM transmiter...RDS and ST.
Well, i do never tested M-Audio and never test Maya..rsrss.
When I put in test the cards i will put the results here.
Thanks Bojcha.
PostPosted: Sun Apr 15, 2012 1:34 pm
Maudio 192 works nicely BUT you have to calibrate ST for FM use. Without calibration you are going to have phase differencies between Stereo pilot and RDS signal.
(if you are going to use it on a pirate/homemade station, then you are good to go out of the box)
PostPosted: Mon Apr 23, 2012 7:27 pm
Ok lef..thanks for your words. I will test first in this week,the onboard card (also 192 khz )...and wil post result here. I did not receive The Mund Audio card...i believed in this week i will receive.
OBS= I have one small FM station official here in Brasil ,ok ?
