Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 1 2 3 4 559 Next
PostPosted: Tue Jan 12, 2016 1:23 pm
ok.
Another Thing:
Could you add a "Drive" control to the post-AGC compressor?
PostPosted: Tue Jan 12, 2016 1:31 pm
ok.
Another Thing:
There is one already! Or at least something with similar functionality.
PostPosted: Wed Jan 13, 2016 2:09 pm
I'm working on something. Which sounds better, A or B?
http://www117.zippyshare.com/v/Oit38gSj/file.html
PostPosted: Wed Jan 13, 2016 2:47 pm
A sounds better, B has some "crunch" in the mids.
PostPosted: Wed Jan 13, 2016 2:54 pm
Not much of a difference but A sounds less harsh to me. Not anything I'd notice right away - very, very subtle.
PostPosted: Wed Jan 13, 2016 3:02 pm
Ok. To me B sounded better but everyone (including people via Skype) prefers A. Back to the drawing board...
PostPosted: Wed Jan 13, 2016 7:52 pm
I like B. It sounds more musical & natural.
PostPosted: Wed Jan 13, 2016 11:57 pm
B sounds better. It has a natural warmer sound.
PostPosted: Thu Jan 14, 2016 2:53 am
7.85 BETA007
Windows stand alone: http://www.stereotool.com/download/ster ... 85-007.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-007.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-007.dll
CHANGED:
- Added a soft of exciter (not an FM exciter but something that generates highs). I've placed it (for now) under True Bass, and it cannot be configured yet. Not really sure what to make of it yet, I think I like it but it does sound a bit "rough" sometimes. Note: It can cause pre- and post ringing at higher latency settings (I will fix that later, first want to get a bit of a feeling for what it does).
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Try "True Bass" for highs -> Probably make a version where different modes (with/without filtering, with better HPF) are tested. Maybe also with multiple bands?? To reduce generated distortion.
- O skin
PostPosted: Thu Jan 14, 2016 2:49 pm
7.85 BETA008
Windows stand alone: http://www.stereotool.com/download/ster ... 85-008.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-008.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-008.dll
CHANGED:
Whoops, turns out that most of the extra highs were filtered out if you enabled other processing. That's fixed now. Also moved the Exciter to the last stage (after the Multibands) to avoid excessive 'sandy'/distorted sound - the Multibands now attempt to get as much highs there as they can, and only if that's insufficient the Exciter will become active.
- Exciter: Check why it sometimes boosts audio around 10 kHz (?) more than it should (Johnnie Cash) - protection filter appears not to work completely. Compare what happens without protection filter!
- O skin
