BETA 761-004
Windows stand alone:
http://www.stereotool.com/download/ster ... 61-004.exe
Winamp DSP:
http://www.stereotool.com/download/dsp_ ... 61-004.exe
- Changed Peak mode behavior in "New Singleband".
The "New Singleband" compressor by design functions as an RMS-level controller, rather than peak level. That's probably good for many things (the level at which it settles sounds much more constant than for peak mode). However, RMS-mode compression also tends to have some very annoying effects, mainly that bass sounds push the level down much further than other sounds, which causes pumping.
Now, this is actually the correct behavior. If you don't consider the fact that to our ears bass does not sound as loud as other sounds, in many cases bass is much louder than any other sound in a mix. Just look at a spectrum and you'll very often see that the bass is dozens of dB's louder than other sounds. The reason that you don't see it in the waveform is that bass usually has the shape of a sine wave, or even a flattened sine wave, while other sounds are moving in all directions (think of voices with asymmetry etc.).
Due to this, using RMS based compression causes severe pumping on loud bass sounds. Also, in many cases a mix on CD has been mixed to maintain a constant peak level, if you feed that through a peak based compressor almost nothing will happen, but an RMS based one will cause the volume to go up and down a lot.
To make a constant sound without pumping, I think using an RMS-based compressor with frequency weighing (basically, ignoring most of the bass) is the ideal solution. This may not keep the peak level constant though, which is also often needed.
So, I've now made a new slider that makes the compressor behave more peak-based. If you change the slider setting on a square wave, nothing will happen; if you use it on a sine wave, the level will drop by several dB when you increase the value of this new slider. For music which goes all over the place the effect is even bigger.
I will add a side chain soon.
- New Singleband: Split Speed into Attack and Release Speed
- New Singleband: Made Attack and Release Speed Threshold relative to Speed - so you don't need to adjust it to change the shape.
