Post new topic  Reply to topic  [ 63 posts ]  Go to page Previous 1 2 3 4 57 Next
 Post subject: Re: Stereo Tool 7.50
PostPosted: Thu Jul 31, 2014 6:06 pm
Maybe i'm doing something wrong but, I can't find the Stream via VLC option in this version!
VLC is installed
PostPosted: Thu Jul 31, 2014 6:08 pm
It`s on Sound cards -> Input. Look in input sound card "drop down menu" listing at the bottom
PostPosted: Thu Jul 31, 2014 6:13 pm
Nop.. doesn't appear anymore... i'd installed ST (64bit) again and nothing
But it was there on a earlier version!
tested it already !
PostPosted: Thu Jul 31, 2014 6:46 pm
Then i don`t know what happened . It`s here on 32 bit and working Ok on my side. May be Hans to say something . 64 bit may have some bug ?
PostPosted: Thu Jul 31, 2014 10:55 pm
Make sure you have 64bit VLC installed.
PostPosted: Thu Jul 31, 2014 10:57 pm
Acr stereo really shines with 80's. I really like the thing that i can only wide up the snare and generally only punchy sounds.
My radio station
http://amradio.ddns.net
PostPosted: Fri Aug 01, 2014 12:22 am
that's it ;)
PostPosted: Fri Aug 01, 2014 8:36 am
I was thinking about the VLC version but i was nearly sure that you install the right one. But nevermind , if now working , everything is fine
PostPosted: Fri Aug 01, 2014 10:45 am
For next version, could you please take extreme tweaker warning off.
"No and don't ask again" does not work, every time I load the VST it askes even if I click "don't ask again." Very annoying!
Is it really necessary?
Just my thought, not that big a deal I guess. :?
PostPosted: Fri Aug 01, 2014 11:25 am
Hello Hans,
There is a Kind of distortion when the declipper is switched on. Source material is clean.
Especially during female speech you can notice this. I have attached my preset.
Hope you can confirm...
Kind Regards,
Robert
I tried your STS file on an Audiobook with a female narrator. I couldn't reproduce the problem. Your STS has declipper off, that sounds fine. When I turn the declipper on (with your STS file loaded), I get no distortion; that also sounds fine.
(I'm using XP32 VST.)
