Ok did not know that.
Activare sync output and see what happens.
Another thing that I do not think I said these problems had appeared when activated the option "Reset output when there is a problem with the sound card." in version 7.42 (which is what I have now) this feature did not exist so this off.
In the past I had problems with the driver Julia:
The sound card was recognized that seconds after stereo tool open.
The solution was a scprit waiting a few seconds before starting ST. (When the system boots)
Also sometimes for no reason is no longer recognized the plate and had to reinstall the drivers.
Then update the drivers to version 1.17. which is the actual last and these problems disappeared.
I have a large buffer of 5 seconds because the pc also receives data from a meteorological station, I have 3 instances of open RadioBOSS, (from there comes the signal streaming air)
And these programs sometimes caused small cuts in the air by the use of the CPU.
Expand buffer to 5 seconds was the perfect solution.
It can play that radioboss streamign via VCL but I have no use to me for several reasons.
Hopefully find where the problem is.
Anyway, I know a little programming, so here I am thinking of building a small application to "listen Output Card" and restart if a siliencio StereoTool.
This will be more stable than a single process as ST works currently, and also let me quiet.
Could also add email notifications when a problem occurs, then I can take action on the matter.
PD:I have windows 7 Ultimate 32 bit.
