Post new topic  Reply to topic  [ 445 posts ]  Go to page Previous 1 2 3 4 545 Next
 Post subject: Re: Preview...
PostPosted: Fri May 01, 2009 2:46 pm
still that strange bug...
if i minimize window and maximize again .. then mess.
and when i move window outside monitor and move back .. then is good.
PostPosted: Fri May 01, 2009 4:13 pm
Ow, you're using the stand alone version... The stand alone version has different windows, and I haven't cleaned them up yet.
Will do so asap.
PostPosted: Fri May 01, 2009 5:13 pm
Great Job Hans,
This is very impressive and easy to use with good look and noticeable changes, please go ahead with it Hans, but i am only suggesting if it is possible to provide 'info messages' as and whenever the mouse moves on top of any of these switching windows prior clicking to alert and advise the user for the required action.
Regards,
Abdul
PostPosted: Fri May 01, 2009 11:41 pm
hello hans ,superb work , but the "bandpass filter " don't run correctly ,with the "output filter" too , on dsp version for winamp.
PostPosted: Fri May 01, 2009 11:49 pm
I know, I'll fix it tonight...
PostPosted: Sat May 02, 2009 5:36 am
Update:
- Stand alone version works properly
- Removed big main windows
- Bandpass filter works
- Turning FM on/off works
- When the mouse moves over a clickable panel, it lights up
- Right-clicking on a panel turns the filter off (not for the Limiting and Loudness panel because it contains multiple filters).
- Different font size setting in Windows should work now.
So almost everything is working now.
PostPosted: Sat May 02, 2009 8:12 am
Stereo Tools appears be to be just what I need to add to my toolbox. Glad it came along with my Media Monkey mojo juice :mrgreen: I'm curious about MPX output, what is the output level; milliwatts? I would enjoy operating a LPFM and any suggestions on what the front end of my exicter-transmitter would need to work would determine if I should :o $$$ in the near future. Thanks
PostPosted: Sat May 02, 2009 10:39 am
Welcome rok-n-rol,
The output level depends on your sound card. So you have to feed the output into an FM transmitter, and then calibrate the volume using (external) measuring equipment so the transmitter signal stays between -75/+75 kHz. For my tests, I'm using a very low power FM transmitter that has cost about 15 euro. The most expensive part is the high quality sound card...
PostPosted: Sat May 02, 2009 10:46 am
Update:
Standalone v...
Much Much Much less bug free. ...
i noticed...
- on startup there is nothing selected for CPU usage + screen updates not remembered after ST restart
- if i open any window (for xample multiband or limiting&loudnes or stereo image or..) and close it, the whole ST is closed .. !?
- on bandpass is minimize button, on others windows not.
- i don't see fix Azimuth in stereo image (oh i must set it manualy)
- and .... where is SoundCard settings
PostPosted: Sat May 02, 2009 1:12 pm
Well done Hans, that is good and logical, whenever the mouse moves over a clickable panel, it lights up,
and also right-clicking of the mouse on a panel turns the filter off.
Abdul
