Post new topic  Reply to topic  [ 42 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Tue Dec 15, 2009 1:38 am
Here is a louder version attempting to "slow down" the final stage using some aural trickery. I'm abusing the "limit" function. Distortion is minimal (good limiter!)
[Common]
Pre amplifier=4
Post amplifier=0.849999964
Extra loudness=1
Extra loudness - Allow extra highs (advanced)=0
Extra loudness - Punchy=0.224999905
Extra loudness - Max Punch peak=0.75
Extra loudness - Deep bass protection - Enabled=0
Extra loudness - Deep bass protection - Value=0.638750076
Bass protection - Enabled=0
Bass protection - Two steps=0
Bass protection - Clip level=140
Bass protection - Deep bass boost=0
Bass protection - Raise clip level if highs get above=150
Bass protection - Maximum clip level raise=35
Hard limit output=0
Process for low latency=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Noise level=5.75
Relative noise gate level - Band 3=1.857142687
Relative noise gate level - Band 4=1.857142687
Relative noise gate level - Band 5=3.651162148
Relative noise gate level - Band 6=3.651162148
Relative noise gate level - Band 7=5.666665077
[Singleband Compressor]
Enabled=1
Difference=0
Maximum volume=3
Attack speed=0.000002539
Decay speed=0.010260966
Above Top Limiter=0.189999998
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Remove remaining loud peaks=1
Maximum volume - Band 1=32500
Maximum volume - Band 2=10000
Attack speed - Band 1=0.000004831
Attack speed - Band 2=0.000004184
Decay speed - Band 1=0.000539601
Decay speed - Band 2=0.000539601
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Very high quality enabled=1
Maximum volume - Band -1=6609.999511719
Maximum volume - Band 0=6609.999511719
Maximum volume - Band 1=6250
Maximum volume - Band 2=6359.999511719
Maximum volume - Band 3=6299.999511719
Maximum volume - Band 4=5250
Maximum volume - Band 5=3949.999755859
Maximum volume - Band 6=3399.999755859
Maximum volume - Band 7=3050
Maximum volume - Band 8=2750
Attack speeds linked=1
Attack speed - Band -1=0.000005229
Attack speed - Band 0=0.000005229
Attack speed - Band 1=0.000005229
Attack speed - Band 2=0.000005229
Attack speed - Band 3=0.000005229
Attack speed - Band 4=0.000005229
Attack speed - Band 5=0.000005229
Attack speed - Band 6=0.000005229
Attack speed - Band 7=0.000005229
Attack speed - Band 8=0.000005229
Decay speeds linked=1
Decay speed - Band -1=0.000314613
Decay speed - Band 0=0.000314613
Decay speed - Band 1=0.000314613
Decay speed - Band 2=0.000314613
Decay speed - Band 3=0.000314613
Decay speed - Band 4=0.000314613
Decay speed - Band 5=0.000314613
Decay speed - Band 6=0.000314613
Decay speed - Band 7=0.000314613
Decay speed - Band 8=0.000314613
Above Top Limiter=1
Clipping enabled=1
Postprocessing enabled=1
Relative clip position - Band -1=1
Relative clip position - Band 0=1
Relative clip position - Band 1=1
Relative clip position - Band 2=1
Relative clip position - Band 3=1
Relative clip position - Band 4=1
Relative clip position - Band 5=0.600000024
Relative clip position - Band 6=0.503759384
Relative clip position - Band 7=0.459854007
Relative clip position - Band 8=0.600000024
Final limiter value=0.501399994
Final limiter decay speed=0.999000013
Final limiter clipping=0.503759384
Equalizer enabled=0
Equalizer position - Band -1=1
Equalizer position - Band 0=1
Equalizer position - Band 1=1
Equalizer position - Band 2=1
Equalizer position - Band 3=1
Equalizer position - Band 4=1
Equalizer position - Band 5=1
Equalizer position - Band 6=1
Equalizer position - Band 7=1
Equalizer position - Band 8=1
[Stereo]
Enabled=3
Stereo AZIMUTH Enabled=1
Stereo Image Enabled=0
Stereo Boost Enabled=1
Stereo Boost Excessive Reverb Protection Enabled=1
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=25
AZIMUTH change speed=0.899999976
Image phase amplifier=2.799999952
Image phase amplifier maximum angle=155.699996948
Image phase amplifier maximum separation strength=75
Image width amplifier=0.699999988
Extra phase shift=0
Mono or stereo only=-0.300000012
Stereo Boost strength=6.5
Stereo Boost maximum amplification=6.5
Stereo Boost multiplier=0.349999994
Stereo Boost - Never reduce below original level=0
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Lowpass filter=17500
Highpass filter=25
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.5
Pre-limiter enabled=1
Pre-limiter relative volume=1.25
Reduced CPU processing=0
[FM Transmitter]
Enabled=0
Pre-emphasize=0
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/|\W"PLAYING %artist% - %title%        "/1s:\T2h\:\T02m\:\T02s/1s:\T2h\:\T02m\.\T02s/1s:\T2h\:\T02m\:\T02s
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing - www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 - www.stereotool.com/30s:\W"%artist% - %title% - %album%"
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=1
RDS Artificial Head=0
RDS Compressed=1
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
[Direct soundcard access]
Enabled=0
Volume=1
Buffer size=1
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Device ID=
Volume=1
Buffer size=0.079999998
ASIO Override channel 1=2
ASIO Override channel 2=3
PostPosted: Sat Dec 19, 2009 5:40 am
This is a really interesting setting.
Is there a setting for the listening end of the stream? I listen to AACplus v2 SBR (not parametric) streams at 64k regularly. The broadcaster doesn't process them before the encoding. I wondered if there were a setting to try to restore and punch up the signal afterwards.
Thanks!
PostPosted: Sat Dec 19, 2009 2:45 pm
Thanks!
Haha... We know each other already I think. This setting is optimized for V1 (I took on the challenge to get HE-AAC at 32kbps to sound as good, if not better than Sirius XM does.) My OS X project is there, but I have to slow down the final AGC stage, and as it stands in Stereo Tool, I cannot do that - so I have no choice but to slam the final limiter slightly to avoid pumping. This does cause some artifacts.
Neural Audio has intrigued me. I'm working on three projects for HE-AAC simultaneously - one of them is a preset for Stereo Tool. You're the same aegrotatio from XMFan I'm assuming, right? Hi! In case you're wondering about the third project, the third project is in hardware.
For the listening end of the stream, there shouldn't be an issue. You should be able to use any generic preset; "Constant Volume - Increased Stereo" built into Stereo Tool, and that should do the trick. Mine tries its best to maintain source timbre, but you can never fully do that without visibility to what is coming in at the input stage of the processor, AT the output stage of the processor. That is to say, "Pre-Limiter (or AGC)", "Multiband", and "Post-Limiter (or AGC)" MUST have visibility to one another at all times to maintain timbre truly. The challenge I have, and it comes from poor habits in my broadcast engineering days - is that this preset progresses, and it gets great, and I think, "Now I just need to make it louder." Unfortunately, I often find I've made all the progress, where the end result is simply me "packing" the audio to make the average output higher.
Let me know if you're looking for a specific preset, and I'd be glad to work on something. They are fun to make!
Here's an updated one:
[Common]
Pre amplifier=3.299999952
Post amplifier=0.799999952
Extra loudness=1
Hard limit output=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Noise level=4.5
Relative noise gate level - Band 4=4.555555344
Relative noise gate level - Band 5=2.508771658
Relative noise gate level - Band 6=4.555555344
Relative noise gate level - Band 7=2.333333254
Enabled=1
Difference=0
Maximum volume=2.5
Attack speed=0.000000543
Decay speed=0.040240694
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 1=97509.9921875
Maximum volume - Band 2=45750
Attack speed - Band 1=0.000002059
Attack speed - Band 2=0.000001781
Decay speed - Band 1=0.000958171
Decay speed - Band 2=0.000958171
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=8309.999023438
Maximum volume - Band 0=8309.999023438
Maximum volume - Band 1=7500
Maximum volume - Band 2=5450
Maximum volume - Band 3=5250
Maximum volume - Band 5=3149.999755859
Maximum volume - Band 6=3899.999755859
Maximum volume - Band 7=2649.999755859
Maximum volume - Band 8=3050
Attack speed - Band -1=0.000013195
Attack speed - Band 0=0.000013195
Attack speed - Band 1=0.000013195
Attack speed - Band 2=0.000013195
Attack speed - Band 3=0.000013195
Attack speed - Band 4=0.000013195
Attack speed - Band 5=0.000013195
Attack speed - Band 6=0.000013195
Attack speed - Band 7=0.000013195
Attack speed - Band 8=0.000013195
Decay speed - Band -1=0.000065476
Decay speed - Band 0=0.000065476
Decay speed - Band 1=0.000065476
Decay speed - Band 2=0.000065476
Decay speed - Band 3=0.000065476
Decay speed - Band 4=0.000065476
Decay speed - Band 5=0.000065476
Decay speed - Band 6=0.000065476
Decay speed - Band 7=0.000065476
Decay speed - Band 8=0.000065476
Above Top Limiter=1
Clipping enabled=0
Relative clip position - Band -1=-1
Relative clip position - Band 0=-1
Relative clip position - Band 1=-1
Relative clip position - Band 2=-1
Relative clip position - Band 3=-1
Relative clip position - Band 4=-1
Relative clip position - Band 5=-1
Relative clip position - Band 6=-1
Relative clip position - Band 7=-1
Relative clip position - Band 8=-1
Final limiter value=1
Final limiter clipping=20
Equalizer enabled=0
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=35
Extra phase shift=0
Stereo Boost multiplier=0.25
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Highpass filter=25
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.5
Pre-limiter relative volume=1.5
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Volume=1
Buffer size=1
Enabled=0
Device ID=
Volume=1
PostPosted: Mon Jan 04, 2010 7:52 am
Another update:
[Common]
Pre amplifier=4
Extra loudness=1
Hard limit output=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Noise level=4.5
Enabled=1
Difference=0
Maximum volume=3
Attack speed=0.000000665
Decay speed=0.002301004
Above Top Limiter=0.289999992
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 2=32500
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 6=4000
Maximum volume - Band 7=1650
Maximum volume - Band 8=1849.99987793
Attack speed - Band -1=0.000012624
Attack speed - Band 0=0.000012624
Attack speed - Band 1=0.000012624
Attack speed - Band 2=0.000012624
Attack speed - Band 3=0.000012624
Attack speed - Band 4=0.000012624
Attack speed - Band 5=0.000012624
Attack speed - Band 6=0.000012624
Attack speed - Band 7=0.000012624
Attack speed - Band 8=0.000012624
Above Top Limiter=1
Clipping enabled=0
Equalizer enabled=0
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=35
Extra phase shift=0
Stereo Boost multiplier=0.449999988
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Highpass filter=25
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.399999976
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Volume=1
Buffer size=1
Enabled=0
Device ID=
Volume=1
PostPosted: Sat Jan 09, 2010 6:49 am
I'm impressed!!!!!!!
[Common]
Pre amplifier=4
Extra loudness=1
Hard limit output=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Noise level=4.5
Enabled=1
Difference=0
Maximum volume=2
Attack speed=0.000000344
Decay speed=0.000763275
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 5=2950
Maximum volume - Band 6=4500
Maximum volume - Band 7=1550
Maximum volume - Band 8=2000
Above Top Limiter=1
Clipping enabled=0
Equalizer enabled=0
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=25
AZIMUTH change speed=0.550000012
Extra phase shift=0
Stereo Boost strength=8
Stereo Boost maximum amplification=8
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Highpass filter=25
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.359999895
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Volume=1
Buffer size=1
Enabled=0
Device ID=
Volume=1
PostPosted: Wed Jan 27, 2010 5:32 am
Latest iteration:
[Common]
Pre amplifier=4
Extra loudness=1
Hard limit output=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Noise level=4
Relative noise gate level - Band 7=3.651162148
Enabled=1
Difference=0
Maximum volume=2.5
Attack speed=0.000004619
Decay speed=0.008889742
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 1=32509.998046875
Maximum volume - Band 2=23500
Attack speed - Band 1=0.000001781
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=8950
Maximum volume - Band 0=8950
Maximum volume - Band 1=8309.999023438
Maximum volume - Band 2=8000
Maximum volume - Band 3=7850
Maximum volume - Band 4=7399.999511719
Maximum volume - Band 5=3850
Maximum volume - Band 6=5950
Maximum volume - Band 7=2159.999755859
Maximum volume - Band 8=3550
Attack speed - Band -1=0.000001086
Attack speed - Band 0=0.000001086
Attack speed - Band 1=0.000001086
Attack speed - Band 2=0.000001086
Attack speed - Band 3=0.000001086
Attack speed - Band 4=0.000001086
Attack speed - Band 5=0.000001086
Attack speed - Band 6=0.000001086
Attack speed - Band 7=0.000001086
Attack speed - Band 8=0.000001086
Decay speed - Band -1=0.001828427
Decay speed - Band 0=0.001828427
Decay speed - Band 1=0.001828427
Decay speed - Band 2=0.001828427
Decay speed - Band 3=0.001828427
Decay speed - Band 4=0.001828427
Decay speed - Band 5=0.001828427
Decay speed - Band 6=0.001828427
Decay speed - Band 7=0.001828427
Decay speed - Band 8=0.001828427
Above Top Limiter=0.75
Clipping enabled=0
Equalizer enabled=0
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=14.999999046
AZIMUTH change speed=0.25
Image phase amplifier=1
Image width amplifier=1
Extra phase shift=0
Mono or stereo only=0
Stereo Boost strength=2
Stereo Boost maximum amplification=3.5
Stereo Boost multiplier=0.550000012
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Highpass filter=19.999998093
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.25
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Volume=1
Buffer size=1
Enabled=0
Device ID=
Volume=1
PostPosted: Sat Jan 30, 2010 3:16 pm
Final Version [For Now]
[Common]
Pre amplifier=5.659999847
Extra loudness=1
Hard limit output=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Noise level=4
Enabled=1
Difference=0
Maximum volume=2.5
Attack speed=0.000006191
Decay speed=0.007614966
Above Top Limiter=0.159999996
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 1=40500
Maximum volume - Band 2=17750
Attack speed - Band 1=0.000001536
Attack speed - Band 2=0.000001536
Decay speed - Band 2=0.000382996
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 5=3050
Maximum volume - Band 6=6100
Maximum volume - Band 7=2850
Maximum volume - Band 8=3750
Decay speed - Band -1=0.001700252
Decay speed - Band 0=0.001700252
Decay speed - Band 1=0.001700252
Decay speed - Band 2=0.001700252
Decay speed - Band 3=0.001700252
Decay speed - Band 4=0.001700252
Decay speed - Band 5=0.001700252
Decay speed - Band 6=0.001700252
Decay speed - Band 7=0.001700252
Decay speed - Band 8=0.001700252
Clipping enabled=0
Equalizer enabled=0
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=25
AZIMUTH change speed=0.349999994
Extra phase shift=0
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1
Pre-limiter relative volume=1.149999976
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Volume=1
Buffer size=1
Enabled=0
Device ID=
Volume=1
CLAJ.zip [2 KiB]
Downloaded 555 times
PostPosted: Tue Feb 02, 2010 6:44 am
I lied. Here's a more stable volume version of the preset above:
[Common]
Post amplifier=0.899999976
Extra loudness=1
Hard limit output=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Noise level=4
Enabled=1
Difference=0
Maximum volume=3
Attack speed=0.000003779
Decay speed=0.050268654
Above Top Limiter=0.469999999
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Enabled=1
Difference=0
Delay enabled=0
Decay speed - Band -1=0.0010933
Decay speed - Band 0=0.0010933
Decay speed - Band 1=0.0010933
Decay speed - Band 2=0.0010933
Decay speed - Band 3=0.0010933
Decay speed - Band 4=0.0010933
Decay speed - Band 5=0.0010933
Decay speed - Band 6=0.0010933
Decay speed - Band 7=0.0010933
Decay speed - Band 8=0.0010933
Clipping enabled=0
Equalizer enabled=0
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=25
Extra phase shift=0
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.359999895
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Volume=1
Buffer size=1
Enabled=0
Device ID=
Volume=1
Listening to the Orban/Omnia was my inspiration here.
CLAK.zip [2 KiB]
Downloaded 524 times
PostPosted: Thu Feb 04, 2010 4:12 am
Here is one which pumps much less:
[Common]
Extra loudness=1
Hard limit output=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Noise level=4
Enabled=1
Difference=0
Maximum volume=3
Above Top Limiter=0.349999994
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 1=8500
Maximum volume - Band 2=8309.999023438
Maximum volume - Band 3=8200
Maximum volume - Band 6=5750
Maximum volume - Band 7=2950
Maximum volume - Band 8=4600
Above Top Limiter=0.539999962
Clipping enabled=0
Equalizer enabled=0
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=25
Extra phase shift=0
Stereo Boost strength=0.75
Stereo Boost multiplier=0.699999988
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.359999895
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Volume=1
Buffer size=1
Enabled=0
Device ID=
Volume=1
CLAL.zip [2 KiB]
Downloaded 529 times
PostPosted: Sat Mar 20, 2010 6:17 pm
This should be the last update, until there may be a new version of Stereo Tool introducing new features.
This is it:
[Common]
Pre amplifier=7.129999638
Extra loudness=1
Hard limit output=1
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Noise level=2.5
Relative noise gate level - Band 4=1.352941036
Relative noise gate level - Band 5=1.352941036
Relative noise gate level - Band 6=1.409638405
Relative noise gate level - Band 7=1.777777672
Enabled=1
Difference=0
Maximum volume=3
Attack speed=0.000001493
Decay speed=0.002917327
Above Top Limiter=0.709999979
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 1=65000
Maximum volume - Band 2=30000
Attack speed - Band 1=0.000002374
Attack speed - Band 2=0.000002059
Decay speed - Band 1=0.00019322
Decay speed - Band 2=0.000139355
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=10000
Maximum volume - Band 0=10000
Maximum volume - Band 1=10000
Maximum volume - Band 3=10000
Maximum volume - Band 4=10000
Maximum volume - Band 5=10000
Maximum volume - Band 6=10000
Maximum volume - Band 7=10000
Maximum volume - Band 8=10000
Attack speeds linked=0
Attack speed - Band -1=0.999998987
Attack speed - Band 0=0.999998987
Attack speed - Band 1=0.999998987
Attack speed - Band 2=0.999998987
Attack speed - Band 3=0.999998987
Attack speed - Band 4=0.999998987
Attack speed - Band 5=0.000034489
Attack speed - Band 6=0.000008546
Attack speed - Band 7=0.000008546
Attack speed - Band 8=0.000008546
Decay speeds linked=0
Decay speed - Band -1=0.999000013
Decay speed - Band 0=0.999000013
Decay speed - Band 1=0.999000013
Decay speed - Band 2=0.999000013
Decay speed - Band 3=0.999000013
Decay speed - Band 4=0.999000013
Decay speed - Band 5=0.000063811
Decay speed - Band 6=0.00010359
Decay speed - Band 7=0.00010359
Decay speed - Band 8=0.00010359
Above Top Limiter=0.680000007
Clipping enabled=1
Relative clip position - Band 5=0.801801801
Relative clip position - Band 6=1.150537491
Relative clip position - Band 7=0.65289247
Relative clip position - Band 8=1.150537491
Equalizer enabled=0
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=9.999999046
AZIMUTH change speed=0.109999999
Extra phase shift=0
Stereo Boost strength=15
Stereo Boost maximum amplification=0.699999988
Stereo Boost multiplier=0.899999976
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=0
Lowpass filter=15000
Highpass filter=25
[Final Limiter]
Enabled=0
Difference=0
Pre-amp=0.5
Pre-limiter enabled=0
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=1
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Volume=1
Buffer size=1
Enabled=0
Device ID=
Volume=1
Adapt3.zip [2.02 KiB]
Downloaded 550 times
