Post new topic  Reply to topic  [ 46 posts ]  Go to page Previous 1 2 3 4 5 Next
 Post subject: Re: Preview...
PostPosted: Tue Apr 14, 2009 11:53 am
Wow i went away for easter and you give us this present :)
Will install and let you know
PostPosted: Tue Apr 14, 2009 1:49 pm
Update: Fixed the time shift problem and the displaying of de-emphasized wave output data.
PostPosted: Tue Apr 14, 2009 2:06 pm
I seem to be getting audio on the rds section of the spectrum
PostPosted: Tue Apr 14, 2009 2:21 pm
Ok, looks like graphs in the stand alone version aren't working properly. I'll look into that.
PostPosted: Tue Apr 14, 2009 2:26 pm
kewl it still looks awesome, stuck a small lcd inside the server cabinet :P
PostPosted: Tue Apr 14, 2009 2:53 pm
when i try enable low latency low quality output for our inside PA system on a different sound card the on air sound stutters
This didnt happen on the old version (3.5?)
PostPosted: Tue Apr 14, 2009 3:41 pm
How high is the CPU load? LQLL + extra filtering + displaying together might be just a bit too much... What happens if you turn the screen update speed down?
PostPosted: Tue Apr 14, 2009 4:17 pm
forgot about that setting will try again tomorrow morning
PostPosted: Tue Apr 14, 2009 7:54 pm
When playing FLAC files the meters are very slow responding.. is this normal?
/MArtijn
PostPosted: Tue Apr 14, 2009 11:41 pm
/MArtijn
I've noticed that too. To reduce the CPU load I'm limiting the screen refreshes to at most once per block of data that is processed by Stereo Tool, with a minimum of 1152 samples (one chunk in an MP3 file). Apparently the blocks that are sent when using FLAC files are bigger.
Increasing the speed in this situation won't really help: On fast PCs the screen updates will arrive so fast that you'll only see the last image anyway, and on slow PCs the processing of the chunk of data would get too much slower, which could result in hiccups.
