Post new topic  Reply to topic  [ 25 posts ]  Go to page Previous 1 2 3
 Post subject: Re: Stereo Tool 6.30
PostPosted: Wed Apr 18, 2012 2:35 am
Found a bug in the AGC. Sometimes when i load a preset the AGC doesn't work.
It then stays at the same level all the time.
Which preset? Any?
PostPosted: Wed Apr 18, 2012 3:13 am
This is when i switch from a preset where gain is reduced to a preset that needs more gain because startup input level is set to high.
Then it goes a bit up but not all the way, it hangs at some point.
PostPosted: Thu May 10, 2012 6:46 pm
I have an idea !!!
MB to have a gating option like the AGC ?
What do You guys say about that ? I think it will be positive for the up coming sound when the song is finish for example ? Or when bass come back again and clipping section has hard work before low up and down speeds calms down the levels .... and so on
Hans do You think like me ?
PostPosted: Thu May 10, 2012 11:00 pm
Planned for the multiband redesign :)
PostPosted: Fri May 11, 2012 6:27 pm
o good :)
really good ! i knew that is a good idea :) But Hans is already planned
