Post new topic  Reply to topic  [ 31 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: Re: De-clipper pricing
PostPosted: Thu Mar 15, 2012 1:49 pm
Hi, got caught up with work and stuff.... But anyway, if you want to use the declipper for lossless music and CPU usage is not a problem, then how would you best set it for the highest possible quality? I ask because I just noticed that at default it is set for mp3 and it seems to remove extra samples, not what I want when playing lossless files.
PostPosted: Thu Mar 15, 2012 4:09 pm
@shckrck: There's a preset for that! (If you use the separate Declipper product, otherwise let me know and I'll look up the settings).
@MilkyJoe: VST is usually used by professional users, Winamp by hobby users. So that's why I don't intend to make a cheaper VST license (in fact, Stereo Tool - even the basic functions that are free in Winamp - is not free in the VST version either).
PostPosted: Thu Mar 15, 2012 5:06 pm
Which preset is it, Hans? Looks like all of them have this mp3 sample removing.
PostPosted: Thu Mar 15, 2012 5:24 pm
Do You hear difference ?
PostPosted: Thu Mar 15, 2012 6:12 pm
Yes, I do. It's slightly noticeable setting it to 0 samples removal, compared to the 1 sample removal default setting on by when playing a lossless file. Especially with headphone listening. I also hear a difference when I move the percentage slider. If there was no difference, I guess it wouldn't have been there in the first place, for it would have been easier to just set it fixed to always remove 1 sample internally, instead of making two sliders that 'do nothing'.
PostPosted: Sun Dec 16, 2012 10:14 pm
any Christmas discounts going on perfect declipper?for those who have bought a Stereo Toll license?
PostPosted: Wed Dec 19, 2012 1:25 am
I decided to have an End-of-the-World sale!
http://register.stereotool.com/
The declipper is now 70 euro instead of 100.
Other prices are lower, or price increases (due to the release of the much improved version 7.00) are delayed a few days.
PostPosted: Wed Dec 19, 2012 11:12 am
I have a de-clipper question.
In Stereo tool many of the Generic presets(10 I think) turn the declipper on by default.Why is this?If you use these Generic presets do you need the De Clipper for optimum results?I´m after the best sound quality possible.
If for example I was to use Bochas Eu4ria without the declipper what would be the effect on processed audio?
PostPosted: Wed Dec 19, 2012 11:39 am
Default de-clipper settings should be already best tuned.
As name say.. without de-clipper, clipped audio will be not de-clipped, but aloso de-clipper knows to add bit of "openess" to some softly clipped sounds.
PostPosted: Wed Dec 19, 2012 12:17 pm
@bob: You know what the declipper does, right?
If not, watch this demo:
http://www.youtube.com/watch?v=oqOljvx9KaM
