Post new topic  Reply to topic  [ 22 posts ]  Go to page Previous 1 2 3
 Post subject: Re: Perfect Declipper
PostPosted: Sat Sep 10, 2011 1:39 am
The Perfect Declipper website is now showing as updated so all is well.
Can you tell me are you just using the default declipper settings on the Metallica track or other Stereo Tool settings as well?
It sounds really quite impressive.
Thanks Michael
All these tracks use only the declipper (well I used the clipper to avoid distortion for the peaks that didn't fit in the output).
Metallica was done using default settings. For some others I used tighter settings, because there it is much clearer which samples were clipped and which were not. But they should sound almost as well at the default settings.
PostPosted: Tue Sep 13, 2011 9:57 pm
I cant see any updated files on the website.
Most likely your ISP uses a webcache/proxy, that's why.
