Post new topic  Reply to topic  [ 25 posts ]  Go to page Previous 1 2 3
PostPosted: Wed May 01, 2024 4:57 pm
Oh that's so awesome that you liked it!
I forgot to turn off Release Holds, by the way, from two bands in MB1. Was experimenting, and it unlocks a lot of mids overall, so make sure to try it out without those!
I'm also very keen on seeing what you plan to do with the bass, make sure to send it when you finish it :D
PostPosted: Wed May 01, 2024 5:40 pm
In the meantime, v2.61 with some tweaks and fixes.
Niv's Adaptive 2.61 HD.sts [166.73 KiB]
Downloaded 437 times
PostPosted: Mon May 20, 2024 7:31 pm
v3.0
- Equalized all of the adaptive parameters for all of the bands, the results are more cohesive
- Turned off Sudden Drop Protection in AGC
- Auto EQ is now super fast
- lots of tweaks all around!
Everything is now very fast and adaptive. Testing it on the recordings of my station's programme and so far liking the results. Music really breathes and kicks in after studio voices as I wanted.
Niv's Adaptive 3.0 HD.sts [166.61 KiB]
Downloaded 358 times
PostPosted: Mon May 20, 2024 11:55 pm
Hi Niv
Thanks for sharing your presets. Here's a little tweak I did of your latest, where I changed the AGC to just be 1 band. It's a more comfortable listen for me, but I know everyone has their preference. I'm mainly listening to dance/electronic, and only for home use, not proper radio.
Cheers,
Ben
Niv_s Adaptive 3.0 1-bandAGC.sts [178.19 KiB]
Downloaded 393 times
PostPosted: Tue May 21, 2024 10:26 am
Hi Niv
Cheers,
Ben
Hey! I've been wondering if I should go one band for quite a while. This is such an interesting topic.
One one hand, having 4 like now, gives more room for pushing certain frequencies to the max, and it's louder and more "technical" in sound.
Having just one, on the other, glues everything nicely in a very unique way. A classic radio sound.
Purely music wise, I think it does flow better with one band. Signal stays cohesive, and does not re-balance every track aggressively, leaving healthy room for multibands to do the work.
What I'm worried about, though, is that at my station we have a lot of reporters who produce content without much audio background. They bring in often dirty, quiet, and raw sounds from their mic's onto the broadcast, and I always wanted to correct for that as much as possible. 4 bands help cover for that on the fly, if only a bit.
Thank you for the preset, I'll be doing more testing.
