Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: Re: Stereo Tool 10.30
PostPosted: Mon Apr 15, 2024 2:12 pm
I was seeing the same thing with missing text etc, on MacOS/Safari. Seems to look fine on Win 11/Edge so far though.
PostPosted: Mon Apr 15, 2024 6:29 pm
Anyone on linux standalone build has a crash if dragging on the zoom/text size sliders?
PostPosted: Sat Apr 20, 2024 2:40 pm
Please add support for skining/collor change for the multiband meters compression and limiting. :)
Garbage in is Garbage out !
PostPosted: Sat Apr 20, 2024 4:24 pm
When I asked Tom about finishing the skinning several weeks ago, he thought the skinning aspect was done enough. When I asked specifically about the meters and scope inheriting the skin coloring, he seemed receptive but I never got a real response. I'll poke him again and find out if it's still a possibility.
I've resigned to designing skins around those base colors -- only changing the background colors. It works well enough to distinguish my games instance from my media instance, which was my main reason for asking for skinning. But I agree it would be so slick to be able to make the entirety of the metering follow the skin: even the spectrograms. But that seems maybe less than optimal.
PostPosted: Thu Apr 25, 2024 4:44 am
I was trying to upgrade to 10.30. Windows 10 keeps flagging it.
Anyone seen this? I was downloading 64 bit standalone.
https://1drv.ms/i/s!AurIFvamcgFUkMJUBrv ... A?e=915AnR
PostPosted: Thu Apr 25, 2024 8:50 am
It's just Windows being very quirky. Some have gotten that and some haven't. It's been very common for Windows to say programs are a "trojan" recently. I've gotten it a few times myself for other programs.
PostPosted: Thu Apr 25, 2024 5:49 pm
It's never happened to me, but the "ml" at the end of the line makes me assume it's Machine Learning. aka an AI based detection that makes mistakes.
PostPosted: Thu Apr 25, 2024 5:51 pm
If you want to verify for yourself if the file is safe to use, scan it on https://www.virustotal.com/ . This runs around 80 different virus scanners on any file you provide.
PostPosted: Sat Apr 27, 2024 2:11 am
Passed all of them, showed suspicious on one.
Likely fine, this isn't the first time Windows has falsely flagged something. On one of the automation machines, there was a period where it thought the UI for my automation was a virus.
This is only the second time that has happened to me, so I wanted to be safe.
PostPosted: Sat Jul 06, 2024 8:34 pm
Any known issues with the Linux jack 10.30 standalone?
