Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2 3
PostPosted: Wed Dec 20, 2023 11:19 pm
Then it's better to start from proper preset and go from there. But again, what is proper preset...
PostPosted: Wed Dec 20, 2023 11:41 pm
I think it's mainly a matter of personal taste. Some will have preferences for presets with more bass, others for more pronounced trebles. Some may insist on creating an optimod preset, even if it's not possible. I think it's important to do it primarily for oneself. I've tried many presets that you've created, and currently, I'm using Unreal Engine 3, which I appreciate a lot.
PostPosted: Fri Dec 22, 2023 9:32 pm
This present is really good – really transparent. Big thanks for sharing. I've turned down the density and loudness a lot, but that's just personal taste.
