Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2 3
PostPosted: Sun Jan 21, 2024 9:37 am
I put it at 10: 20 last night and it works great. It's a great preset.
PostPosted: Sun Jan 21, 2024 9:56 am
Is this preset made for the adaptive compressor that is in the new Stereo Tool or is it made for the old compressor that is in the older versions?
Hi afaik the new adaptive compressor is from v10.20 and on and i' m using 10.10 BUT i have made an "adaptive" sidechain in AGC which increases 0.5db when there is a solo instrument or a vocal part without other instruments present. It feels like a more "live concert" feature like when you have the mixing engineer increasing the levels on single vocal or instrument parts.
PostPosted: Sun Jan 21, 2024 10:04 am
Thanks for the feedback.FYI im trying some modifications and i believe V.1.9 will be more interesting :D
PostPosted: Sun Jan 21, 2024 10:22 am
I would love to try the new adaptive compressor mode because it is very good. He does particularly well with songs where there is already a lot of compression.
PostPosted: Mon Jan 22, 2024 11:57 am
Dumans: Just don't increase the volume of the new preset, because believe me, the loud modulation is enough, as well as the aggressiveness of the presets. I don't know if you have contact with hansa, but it would be good if he included this last setting of yours in the processing settings in the new stereo tool version, with the fact that I would name this balance setting as dumans concert balance. It really sounds like I'm at a concert. Aggressive just the way I like it when I take off my hearing aids and listen through the speakers. I suggest that you make another setting that would be the same balanced, only a much milder version without this concert aggression, and that would be a different sound than this perfect concert that we have. It would be good if we had two balanced types of sound. I also see that sound as an even sound, only with much quieter compression and aggression. This is what I mean when you get the time you could try to do it. Still go with the concert version of the sound, it's perfect. I think if you were in the team setting up the widex hearing aid processor, their processor would actually program exactly that balance that they have never properly achieved on hearing aids and if I adjusted my widex pasion yunic 400 very well to my liking. Believe that it is similar to the stereo tool, only a little more advanced, but not when it is adjusted with their software, but when the processor is programmed globally.
PostPosted: Sun Feb 04, 2024 11:51 pm
the phase sounds on my instruments with this settings not very good
