Post new topic  Reply to topic  [ 63 posts ]  Go to page Previous 1 2 3 4 57 Next
 Post subject: Re: BigFlex6 HD
PostPosted: Sun Oct 30, 2022 8:20 pm
Thank you Bojcha. Quite impressive!
The only thing is, that we need to be in the region about 3dbr.
If I lower clipper, the result is not the same, otherwise great great preset.
I Didn't calibrated for that.
However, you can try to set bass to -2.5, and set clipper lower to about -1.00 and turn OFF sidechain in AGC, or just use BS412.
Thnx. I eill try that. One thing that I saw in 2nd mutiband - threshold for bands doesn't make any difference if ratio is 1.0:1.
Are 2 bands only made for limiting in 2nd band?
PostPosted: Sun Oct 30, 2022 9:39 pm
Yes, slightly rms bass leveling in B1, and b2, b3 only limit.
PostPosted: Mon Oct 31, 2022 11:16 am
Here is example. Your slightly modified preset (around +3dbr) and then mine:
https://www.dropbox.com/s/v6h2o4crizkr8 ... 2.wav?dl=1
Not quite much difference :)
PostPosted: Mon Oct 31, 2022 2:25 pm
That standard is so bad in my oppinion, once i tried to make it to be constant and i gave up. This preset is not good candidate for that too.
spectrum curve is so bad for that measurement, you should kill bass and pretty much highs.. idk i might try again.
PostPosted: Mon Oct 31, 2022 3:10 pm
Yeah, I agree. It's much easier to push it to the max clipper, but whatever I tried, still, your preset does not sound so bad.
BR.
PostPosted: Fri Nov 04, 2022 10:15 pm
V0.13BHD preset ok
V0.19HD no sound!
PostPosted: Fri Nov 04, 2022 10:23 pm
V0.13BHD preset ok
V0.19HD no sound!
Just checked and there IS sound.
PostPosted: Fri Nov 04, 2022 10:26 pm
Thankyou!
then I have the problem, I load it and there is silence....
PostPosted: Fri Nov 04, 2022 10:30 pm
Thankyou!
What ST version you use? also Standalone, DSP.. new or old gui ?
PostPosted: Fri Jan 06, 2023 5:21 pm
Final version(s) posted.
