 Post subject: Re: Stereo Tool 9.60
PostPosted: Mon Nov 16, 2020 2:44 pm
Some minor QOL improvements:
Would it be possible to display the currently active ratio when "Progressive Ratios" (or is it dynamic ratios? I'm not certain) is enabled?
Also, it would be handy to have all frequencies listed beside each band in the new "Per Band" page of the AGC.
PostPosted: Mon Nov 16, 2020 3:19 pm
hi
MRKLOROX can i ask you??? the equalizer in the new version works for you properly????
PostPosted: Mon Nov 16, 2020 8:54 pm
hi
The normal one labeled "Equalizer" on the main processing page works for me, yes. Make sure to try placing it in different places in the chain.
However, if you're trying to use the new AGC to shape or color your sound, that's what the "Per Band" Main relative loudness sliders help with. Together with the band placement, you can color your sound much like an EQ would.
I don't believe the sidechain PEQ works like you're wanting it to. Somebody else can certainly explain that one better than me.
PostPosted: Tue Nov 17, 2020 6:00 pm
it would be useful for an asterisk to appear on the preset or change color when changing a parameter ... voluntarily [or] unintentionally.
I concur. An asterisk on the title bar or preset field would be handy and when attempting to design one. There's not currently an easy way to compare and contrast presets other than A/B ing.
The idea of coloring a setting that's been affected is indeed interesting.
PostPosted: Tue Nov 17, 2020 10:14 pm
I guess nobody ever noticed... but settings that have been modified have 2 white dots on the right side.
PostPosted: Tue Nov 17, 2020 10:33 pm
Oh wow, I feel so unobservant :o
I did notice those dots, but I didn't make the connection that that's what it was signifying. :oops:
PostPosted: Tue Nov 17, 2020 10:44 pm
Let me guess.... you thought it was a display bug? :)
PostPosted: Tue Nov 17, 2020 10:45 pm
In the mean time, version 9.62 is released. Mainly because there was an issue in 9.60 and 9.61 that caused the CPU load to be too high.
PostPosted: Tue Nov 17, 2020 11:46 pm
Hello Hans,
There is a display bug with the AGC when in "Basic" position (Per Band)
This happens when you change presets
even starting from zero if you set to "Basic" position the bug appears
PostPosted: Wed Nov 18, 2020 2:00 am
Tiny UI Bug?
This seems odd - like the bottom two were meant to be displayed against the 3 and the 4
This is the Winamp version, 9.62
