Post new topic  Reply to topic  [ 47 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Thu Nov 12, 2020 9:21 am
wooh.. optimod? Optimod will never allow to be like those 2 presets in their units. So no, it does not sound like optimod.
Glad to always have your optimism around.
PostPosted: Thu Nov 12, 2020 4:45 pm
Goedemiddag Mathijsco,
Kan het kloppen dat je in je laatste preset de sub bass boost hebt uitgeschakeld?
De preset wordt steeds beter complimenten!
Grt Glenn
PostPosted: Thu Nov 12, 2020 8:55 pm
Do you have Sub Bass Boost on in your last preset? It doesn't charge when I load DCM from my PC.
There was a bug in the saving of that setting, it's supposed to be on in this preset but it may indeed be off if you load it from this file. So, please turn it on manually.
@ Glenn FM
PostPosted: Sat Nov 14, 2020 8:47 am
als ik deze preset inlaad (laatste update).. staat de input volume sky high hoe krijg ik die naar beneden.. nog nooit last van gehad. vorig versies van de moose zijn wel goed.
vgr...
PostPosted: Sat Nov 14, 2020 7:15 pm
vgr...
Je moet daar het niveau verlagen
Gebruik bij het laden van de voorinstelling niet de optie "All Settings (Import)"
https://fmfeeling.com
PostPosted: Sat Nov 14, 2020 7:30 pm
thnx... hoe kon ik hem over het hoofd zien.. mijn dank is groot. :D :D
PostPosted: Mon Nov 16, 2020 2:11 pm
This version of the preset changes:
  • Changed highs boost from equalizer to band mix in MB1, which sounds more natural
  • Changed clipper settings for highs to make them sound less "forced" and more open (only noticeable in FM mode or when clipped hard)
  • Properly enabled TB / Sub bass boost again (it should have been enabled in the previous versions as well)
  • Disabled TB band 2, it's simply too much for now
  • Changed low-end to be more punchy and less mushy
  • Allow for more mids so it sounds more 'defined'
Dutch Chocolate Moose.sts [401 KiB]
Downloaded 554 times
PostPosted: Mon Nov 16, 2020 9:36 pm
Ehh.. spectrum waaay better now.
PostPosted: Sun Dec 20, 2020 2:08 pm
Hello,
can it be true if you use this preset and you switch off the licenses "auto eq dynamic spectrum that the sound on the radio via micrompx sounds very bad. Like pumping, clipping? I have never had problems with this present if I do not have the license options, but now via micrompx the sound is bad.
PostPosted: Mon Dec 21, 2020 1:15 am
Hello,
Maybe the "like pumping, clipping" sound that you hear is because the free features don´t includes de "advanced clipper", and others feats. like the 4 band AGC and declipper.
