Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2 3
 Post subject: Re: VBP
PostPosted: Wed Jul 17, 2024 11:05 am
You are absolutely right. This sounds exactly like KISS FM Romania (the #1 CHR station here) with uses Orban Optimod 8400. This is the best open-sounding preset I found in the past 5-7 years on this forum. There are a bunch of similar presets but they distort, this si crystal clear. Congratulations man! You are amazing!
PostPosted: Wed Jul 17, 2024 9:17 pm
This is the best preset for the ST 10x so far. The preset is loud and none of the sound spectrums are overpowered. Great job. Kudos to @Bojcha for the work done.
PostPosted: Thu Jul 18, 2024 1:03 am
I use this preset since 2022 and I can assure that there's no other better than it. I asked Bojcha to update it, cause it's so good that it doesn't deserve to be lost in the past. I'd like to ask Hans to put it as a preset in the next version of ST.
