Post new topic  Reply to topic  [ 28 posts ]  Go to page Previous 1 2 3
PostPosted: Tue May 05, 2020 12:58 am
BETA018 posted! Biggest change: There's now also a harmonics filter for Immersive Bass. Which can be used to reduce the level of higher harmonics which makes it sound - lacking a better description - 'more kind' or 'rounder'.
There's might be something weird when adjusting the filter strength slider, it's ok at 0% and 100% but I need to check what's going on in between.
PostPosted: Tue May 05, 2020 6:43 am
Some of those are still older versions, and some of them have crashes. I will post it when it's ready, which will be in a few hours.
Apologies. Thanks for the b18 update! :)
PostPosted: Tue May 05, 2020 10:48 am
Hi Hans, I posted this in the "wish list" section but I think you may not have read it.
Would it be possible to "unfreeze" all gates (AGC / MB1 / MB2) for a few seconds when another preset is selected? The idea is to get a smoother transition between presets. As an example, I'm using standalone version 9.40, and switching from Studio One web/DAB preset to Lunas web/DAB really takes too much time, sometimes the gates remain frozen and some bands are stuck for a very long time.
Is it possible to get this fixed?
Thanks!
PostPosted: Wed May 06, 2020 2:48 am
Thanks!
Good idea. I'll put it on the todo list.
In the mean time, BETA019 is posted!
PostPosted: Wed May 06, 2020 8:08 am
Thanks!
PostPosted: Fri May 08, 2020 4:42 am
BETA020 is availabe. Main change: There are now soft clippers in the multiband. I haven't really tested them yet but on first glance they seem to sound more natural, more open and dynamic. It's kinda like a clipper/limiter hybrid.
PostPosted: Sat May 09, 2020 10:47 am
BETA021 is available. Biggest change: 2nd stage bass clipper enabled in Asymptotic mode, and the harmonics filter can be run before or after that. Before causes louder harmonics on loud peaks.
PostPosted: Sat May 09, 2020 11:22 am
can you give a update about when the new web interface will be introduced?
Thanks
