Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 37 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Mon Apr 27, 2020 5:12 pm
you think...how you know??? have you mesure it??? i mean have you test it??? and how do you have test it??
PostPosted: Mon Apr 27, 2020 6:45 pm
there are some obvious differences, i also listened to a song live for a few seconds and then listened to it with the default preset
Prime Сasual Dating
PostPosted: Mon Apr 27, 2020 7:20 pm
ok
with the ears you have the diff...hmmmm very strange this bcs in default factory settings STEREOTOOL is flat ....other THERE ARE NOT...and this makes the difference for the stereotool....check again pls and what age do you have??? :) bcs me my friend never trust my ears ...i,m using only instruments...and believe me never i have done mistake bcs those tell you the truth so the ears is the start and the instruments is the last ....have a nice day my friend... :D
PostPosted: Mon Apr 27, 2020 9:18 pm
I have already analyzed it with several programs, it's not the default preset, I think it's just developed from the default preset.
Prime Сasual Dating
PostPosted: Thu Apr 30, 2020 1:34 pm
Hey,
of course that's a matter of taste, but I like the sound and I'm still looking for someone who will reproduce it for me.
Prime Сasual Dating
PostPosted: Fri May 01, 2020 4:35 am
Why the hell you want to pay for a preset that will sound so bad.. The station that you want to replicate sound very bad... :D
https://fmfeeling.com
PostPosted: Fri May 01, 2020 9:13 am
There's no "bad" and "good" in sound. It's purely a matter of taste. I rather like how that station sounds for example.
Stop discussing whether it's bad or good, that's going to be endless.
PostPosted: Fri May 01, 2020 8:25 pm
Ok, you're right. For bad sound I meant that it sound very distorted...
PostPosted: Sun May 03, 2020 12:12 am
Okay, I'm still looking for someone.
Prime Сasual Dating
PostPosted: Wed May 06, 2020 12:41 pm
Friend! I really root for you! I want to find someone who can make a preset with the same sound as on this radio, because I also really like that sound! I would also like to know or get a ready-made preset!
