Post new topic  Reply to topic  [ 31 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Thu May 07, 2009 7:18 pm
That's the font, but on my screen some of the text along the right hand side is garbled.
Also, I've noted: clicking one of the "Quality" buttons cuts the volume almost to zero; not sure how I got it back; and, right-clicking ST in the system tray appears to turn it off, but I can't actually close the program that way.
PostPosted: Thu May 07, 2009 7:20 pm
Almost forgot -- in Media Monkey (which is supposed to be based on the Winamp engine), ST makes the hardware "next track" button on my computer function like a pause button. Doesn't seem to happen in Winamp.
PostPosted: Thu May 07, 2009 7:28 pm
Er... I don't see anything garbled?? What do you mean?
About the volume that drops to near-zero: I cannot reproduce that here, can you see if any of the settings is changing (if it is, the pre-limiter or multiband green-to-red bars will probably get filled completely without any white on top).
The repeated presets problem is fixed now and I'm working on the other issues, I expect to have a new beta ready tonight.
I don't have a clue what that media monkey problem is - do you know if it also occured with older versions?
PostPosted: Thu May 07, 2009 7:53 pm
Re garbled: okay, on closer inspection it's not garbled, it's just run together and not real clear. "CPUusage&latency" had me fooled, as did "Screen update spd." Maybe my eyes are going, but it might be nice to have a little more real estate there.
PostPosted: Thu May 07, 2009 8:05 pm
I guess I should make characters like 'i' and 'l' smaller, so I have more room to add some extra spaces there :-)
By the way, Configure button problem seems to be solved -> fix will be available in tonights beta.
PostPosted: Thu May 07, 2009 11:14 pm
Update is available, same link as before: http://www.stereotool.com/download/dsp_ ... _BETA2.exe
Changes:
- Configure button should work now
- Repeated presets are gone
- If a different window is activated after selecing a preset, the preset pulldown menu is no longer selected - so returning to the main window does not cause changes in settings and disruptions of the audio anymore.
- After a pause of 1 second (I'll make this configurable later, didn't have time for it now...) all buffers are flushed. So if playback resumes the end of the previous song is replaced by silence.
- Text at the right of the screen should look a bit better (mainly because I rephrased the text)
- Most output sliders are now changed such that they move simultaneously. Tomorrow (probably) I'll add a configuration slider to enable setting a delay that's identical to the Winamp buffer size so everything is displayed simultaneously with the matching sounds.
PostPosted: Thu May 07, 2009 11:57 pm
Config works. Presets good (although I find selecting and exiting the presets menu still causes an interruption in sound, whether or not the preset is changed). Text much cleaner.
Re the buffer flushing - Skip to next/previous track performance is unchanged (as expected per your change description).
Upon a pause, in Winamp the music stops immediately but the track location marker jumps ahead slightly (by the length of the flushed buffer?); when I hit play again the music starts up perfectly, but slightly further along, i.e. there is always a gap in playback with a pause/play operation.
Interestingly, in Foobar (using a bridge to Winamp plugins and with ST enabled), the music pauses and restarts perfectly, but then almost immediatly after restart there is a hiccup, or cutout, and then things go on normally from there. Perhaps that provides some clue as to what is happening when skipping tracks?
Any way to get rid of the interruption in sound almost anytime a box is checked or new window selected? I understand that applying the new settings may cause a blip, but there's really a lot of "static." Also, exiting some windows causes focus to shift back to the Winamp options window, when it ought to stay with ST until ST is closed/minimized.
Hope this helps!
PostPosted: Fri May 08, 2009 12:17 am
Selecting does do that - because the preset is re-loaded. Deselecting shouldn't - I'll look into that...
Yes, that's what is to be expected because I'm silencing some data.
That would indicate that either Foobar or the bridge is also using a buffer - between Stereo Tool and the sound card. I cannot touch any data that has already left Stereo Tool (unfortunately...!).
However I will make the silencing configurable, so you can turn it on or off depending on whether you're using Foobar or Winamp.
About the interruption: Not really. If a new filter is turned on, it causes some extra delay - so I have to send some data, and currently that data is silence. I could try things like repeating a slice of data etc., but I'd have to change a lot of places where this occurs. The other alternative is to ALWAYS delay the playback regardless of whether the filters are on or off. That should work, but delays are also annoying...
Hope this helps!
Definitely!
By the way, regarding the silence/static when changing settings: It might be possible to reduce that by checking if a filter is being set to a value that it already has. If so I could skip clearing the buffers (which is currently done when a filter is turned on or off - previous versions of Stereo Tool played back some data from the last time the filter had been on which is even more annoying).
I'm not going to fix this for the next release, but I'll keep it in mind for future versions (I'm going to work on some other stuff in the next few weeks, and I want to release this version asap so I have time for that other project...) I still want to completely redesign the presets, because I think the current list is not easy to use - and it doesn't contain enough good presets. And if I add more it will just become more crowded. Eventually the input/output volume and presets should also be changed to the new interface. But I think I'll do that later.
PostPosted: Fri May 08, 2009 6:06 pm
and that is why i use standalone version of ST .. even with winamp. 8-)
PostPosted: Fri May 08, 2009 10:39 pm
I just discovered that most of the gaps when switching between settings were caused by a bug in the final limiter. That's fixed now, and I can now - for example - switch between all the FM presets without gaps.
Will be available in tonight's beta.
