Post new topic  Reply to topic  [ 30 posts ]  Go to page Previous 1 2 3
PostPosted: Mon May 09, 2011 11:18 pm
The download link doesn't work for me for the Linux GUI or cmd (cmd is the one I want) version?
tim
PostPosted: Tue May 10, 2011 12:02 am
Are you talking about the links on the download site? They work fine here...
If you're talking about BETA's: I usually don't have my Linux VMware-images running, so that's why I usually don't build them each time. I will when a new version gets released.
PostPosted: Tue May 10, 2011 1:38 am
No, just the standard download links for Linux?
From the US of A:
curl -v http://www.stereotool.com/download/stereo_tool_cmd
* About to connect() to www.stereotool.com port 80 (#0)
*   Trying 64.22.89.243... connected
* Connected to www.stereotool.com (64.22.89.243) port 80 (#0)
> GET /download/stereo_tool_cmd HTTP/1.1
> User-Agent: curl/7.21.3 (amd64-portbld-freebsd8.2) libcurl/7.21.3 OpenSSL/0.9.8q zlib/1.2.3 c-ares/1.7.4 libssh2/1.2.8
> Host: www.stereotool.com
> Accept: */*
* Empty reply from server
* Connection #0 to host www.stereotool.com left intact
curl: (52) Empty reply from server
* Closing connection #0
Exit 52
From New Zealand:
micro:~> curl -v http://www.stereotool.com/download/stereo_tool_cmd
> User-Agent: curl/7.21.0 (i486-pc-linux-gnu) libcurl/7.21.0 OpenSSL/0.9.8o zlib/1.2.3.4 libidn/1.15 libssh2/1.2.6
> Accept: */*
I get the same "Empty Reply" message in Chrome. Other download links work just fine.
Tim
PostPosted: Tue May 10, 2011 12:08 pm
Odd, yesterday I just tried if I could save the file (without actually saving it - just to check if the link was valid). Now I did save it and it's indeed empty (0 bytes). It worked before! So apparently some configuration on the server must have changed which somehow causes issues - probably with files without extention.
Will have to check how to solve it (renaming, zipping, ...).
PostPosted: Fri May 20, 2011 12:49 am
Not sure what you did, but it's fixed now :)
Thanks!
PostPosted: Fri May 20, 2011 1:38 am
That's scary, because I completely forgot it and I haven't changed anything..............
I think it must have been some server setting, and my provider probably got complaints about it when they changed the behavior.
PostPosted: Mon Dec 17, 2012 8:06 pm
any ETA for the version 7 of Stereo Tool?
PostPosted: Sat May 04, 2013 10:29 pm
Ok I need a little help. I downloaded the linux stereo_tool_gui.
next issued the: chmod 755 stereo_tool_gui
Next i tried to ./stereo_tool_gui and got:
./stereo_tool_gui
bash: ./stereo_tool_gui: No such file or directory
I'm on ubuntu 12.04 with an amd64 3200 desktop
can someone give me a hand?
PostPosted: Tue May 14, 2013 11:42 am
agrapha,
can you do:
#> ls -ldtr *stereo*
#> file *stereo*
#> ldd *stereo*
and post the results?
Bart
Web: http://www.contact-dance.com
Request system: http://www.contact-dance.com/c-request
FB page: https://www.facebook.com/ContactDance
PostPosted: Tue Jun 04, 2013 5:39 pm
Could you guys check if the new 7.24 version starts up without requiring external library installs?
viewtopic.php?f=14&t=4846&p=21206#p21206
