Post new topic  Reply to topic  [ 239 posts ]  Go to page Previous 1 2 3 4 524 Next
 Post subject: Re: StudioOne HD
PostPosted: Sat Sep 28, 2019 4:09 pm
Hi, Bocca, sorry again for bothering.
I wish you could help me setting the ACG gate. I mean, I would be grateful to you if you could explain me the logics, according to which fine it according to my levels, to reduce glitched sounds.
I'm not sure if I have to rise it, lower it, rise the gain etc.
Thanks in advance
PostPosted: Sat Sep 28, 2019 10:02 pm
Thanks in advance
It only depends on your Input level. If your input level is low then gate also need to be low. Dont look numbers, play some track and when there is some soft part in track gate should light up a bit.
PostPosted: Mon Sep 30, 2019 3:41 am
Bojcha posts a new preset and wow, it's like feeding time. Everyone jumps on it like "rahh yum yum" myself included. :D
Love it!!
PostPosted: Mon Sep 30, 2019 4:18 pm
Love it!!
Where can I download the update? I see only the link for the 0.14 version
https://fmfeeling.com
PostPosted: Tue Oct 01, 2019 3:46 pm
Yes, same here. It appears the post didn't get the attachment for version 00.32
PostPosted: Tue Oct 01, 2019 3:51 pm
I wanted to upload but still waiting one feature and one fix to be added in ST.
PostPosted: Mon Nov 04, 2019 3:40 pm
For those curious or looking for an updated version of this preset, Studio One appears to have made it into the integrated Stereo Tool presets.
PostPosted: Mon Nov 04, 2019 3:53 pm
Nice!!! What is the version included, Bojcha?
PostPosted: Mon Nov 04, 2019 8:18 pm
00.14
PostPosted: Sat Nov 16, 2019 1:13 pm
Hi Bojcha, sorry to bother you again. I noticed that sometimes, in music, voices or other sounds push down other frequencies, expecially drums or other bass sounds (I don't know if it is the update or other setting Imight have messed up). Any suggestgion to make the sound more"stable"?
Thanks in advance
