Post new topic  Reply to topic  [ 78 posts ]  Go to page Previous 1 2 3 4 58 Next
PostPosted: Fri Feb 01, 2019 2:53 pm
I still dont uderstand what you are doing and still window speed does not do what it should do at all.
Could you clarify? Inside the window it now slowly moves to the place where it would have been without a window. That should be the correct behavior?
PostPosted: Fri Feb 01, 2019 3:08 pm
It's not. No metter what settings it act like freezed speed now.
PostPosted: Fri Feb 01, 2019 3:24 pm
Not here. Try 0.1 seconds, that should act almost as if there's no window. If you still see it freeze, please send me your settings so I can see what's going on.
PostPosted: Fri Feb 01, 2019 3:36 pm
Default settings just AGC ON with 400Hz input tone. Set and dB window and it will not stay at position like without window.
Or AGC meter lie to me...
edit:
Yes, AGC meter shows wrong.
PostPosted: Fri Feb 01, 2019 6:57 pm
The window moves the threshold. Before that was needed because - when you couldn't move inside the window - there was no way to ever get back to no attenuation. I can't remove that behavior without breaking every preset made to date.
If you play constant tones and look at the behavior inside and outside the window it should be clearly different.
PostPosted: Fri Feb 01, 2019 11:29 pm
Ok, can agc meter be fixed?
PostPosted: Sat Feb 02, 2019 4:13 pm
Hans, this beta (007), the preset is not correctly saving the AGC settings.
PostPosted: Sat Feb 02, 2019 4:15 pm
I've been also same problem!
Control point
PostPosted: Sun Feb 03, 2019 12:15 am
I've just tested it but I don't see any problems. Can you tell me exactly what you're doing and what doesn't get saved/loaded?
PostPosted: Sun Feb 03, 2019 2:13 am
The stereotool does not save the *.sts correctly but the% USERPROFILE .ini file is saved correctly, or the settings remain in the program if you do not change the preset but if you save it and want to go back it is not possible because something is missing being thus, the preset was not saved.
