Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2 3
 Post subject: Re: AGC Window speed
PostPosted: Thu Jan 31, 2019 10:33 am
This can be set with one slider. 0-1x window speed of main AGC speed.
Also it does not work in Current AGC as should. Speeds are always very fast in window.
Confirmed. I made it in 2 stages (and tested the first stage, then added the 2nd), I must have broken something when I added that 2nd stage. :(
Edit: No, the calculation of the movement speed was wrong (and I tested it with very high AGC speeds to quickly see what it did, for slower AGC speeds it has no effect whichever setting you use). I have now replaced the speed by a half-life time, basically, the time it takes to get half-way to the 'actual' (without-window) level. At 0.1 seconds it acts like there's no window, at 100 seconds it's turned off (same as before 9.23-006). Will be available in the next build (9.23-007). For now, you can still use the max speed sliders to control the maximum speed inside the window. But that's a constant value then, not dynamic.
PostPosted: Thu Jan 31, 2019 10:15 pm
Reading 3 times.. still dont get it. This should be very simple..
PostPosted: Thu Jan 31, 2019 10:45 pm
New build is running. It's definitely not simple... and there are lots of different ways to implement a window that all have different advantages and drawbacks.
