Post new topic  Reply to topic  [ 143 posts ]  Go to page Previous 1 2 3 4 515 Next
PostPosted: Sun Nov 11, 2018 9:17 am
Hans, am I missing a way to get tones out of the software when not running 192kHZ? For AM and some FM usage, I'm using a Henry USB Matchbox II as an output "card". This gives me analog or AES outputs at 44.1kHz, but tones don't appear to work under this configuration.
Also, when you have nothing else to do, perhaps a gate indicator on the low-level boost filter?
Thanks.
PostPosted: Wed Nov 14, 2018 12:49 pm
Stereo Tool 9.12 BETA005
Windows 64 bit Windows stand alone on Windows 10 Pro 1803
Stereo Tool in bypass while looking into audio quality issues (trying to isolate whether distortion in low end was incoming or from processing).
Attended to other work, came back about 2hrs later with the following...
Closed error, sound came back in processing but CPU was running 15-20% higher?
Shut down ST, restarted and CPU came back to normal level.
Thought I'd better log the error in case it means anything...
Ross
PostPosted: Fri Nov 16, 2018 9:53 am
Stereo Tool 9.12 BETA006
Windows stand alone: https://www.stereotool.com/download/ste ... 12-006.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 12-006.exe
VST 2: http://www.stereotool.com/download/vst_ ... 12-006.dll
VST 3: http://www.stereotool.com/download/vst_ ... 2-006.vst3
VST 2: https://www.stereotool.com/download/vst ... 12-006.dll
VST 3: https://www.stereotool.com/download/vst ... 2-006.vst3
  • CPU load 100% in web thread Linux?
  • No ASIO asserts in debug mode
  • Group 15B also send 4x on TA start (was only doing it on end).
  • Added odd/even harmonics selection in Basstardizer (was only odd before).
  • Nicer input sound card open error handling (softer beeps, retrying and restarting added).
  • RDS: Add PIN to interface
  • VST3 plugin
  • Volume display FM output seems wrong when streaming output is enabled with separate processing. Almost certainly only GUI issue.
  • Noise gate windows audible
  • Auto-select 192 kHz FM output sound card as default
  • No PIN EWS
  • Look at text alignment
  • Split RDS features in standard and advanced RDS (EON, AF method B, ECC, EWS, ODA - TMC etc)
  • RDS AF method B
  • RDS AF method B via UECP Probably done but can't test it now.
  • White screen in generic plugin - was caused by wrong #ifdef
  • I/O and BIMP missing in web interface.
  • RDS: UECP: Site and Encoder address were swapped. Fixed, not tested.
  • VST3 plugin doesn't work in vMIX PROBABLY FIXED
  • Odd/Even harmonics switch for Basstardizer BUSY
  • 1024x600 screen misses VU meters
  • Hanegraaff
  • MicroMPX: Add manual (how to setup)
  • AAX plugin
  • Glitch when turning Bypass off
  • Linux MicroMPX version
  • Right-click tray icon bypass is bad
  • Dutch Moose schelle vrouwenstemmen
  • Linux-version MicroMPX integration in ST.
  • Support for more than 32 ASIO channels
  • Automate generating MicroMPX licenses
  • Automate generating The BIMP licenses
  • Backup audio doesn't go to LQLL
  • Finish Kantar tests and integration
  • Brian, NAB
  • VST for DJB
  • Test sound card
  • Linux multiple instances
  • Fake stereo idea
  • Cntrct IN
  • Add a popup for buffer overrun/underrun (also for suspicion)
  • Test ProppFrexx Windows 2012 server issue-
  • RDS: RT end at \n
  • Noise in declipper issue
PostPosted: Fri Nov 16, 2018 4:03 pm
I tried to install the 64 bit VST3 version, unfortunately without success. The file is loaded by Adobe Audition CC but it is not shown in the plugin list. It looks like he can't really load the plugin. Any ideas?
PostPosted: Fri Nov 16, 2018 4:09 pm
Something seems to be broken. It worked a few days ago... but I can't load the latest build either. Looking into it now!
Edit: O. Debug works. Release does not even get recognized. Settings are virtually the same. This will take some trying (remove different settings and turn them back on one by one).
Edit 2: Found and fixed. An entry point wasn't present in the release version. Next build should work.
PostPosted: Sat Nov 17, 2018 12:13 pm
Ross
It probably does..... Unfortunately I forgot to backup the code for version 005 and I can't find the error location in the code :( . Just to make sure: I assume that this happened when you turned Bypass *OFF*? Since ProcessingChain shouldn't even be active in Bypass mode.
PostPosted: Sat Nov 17, 2018 2:11 pm
I've been waiting patiently for a ST VST3 release to use in Adobe Audition. I tried the VST3 right away with no luck. I did research online to see what could be wrong and found that Adobe actually had a bug that would not list certain VST3. Apparently v11.0.2.2 released earlier this year https://forums.adobe.com/thread/2441501corrected the problem. I had an older version which would have been affected by this, but I also have a newer version. No luck on either. :shock:
PostPosted: Sat Nov 17, 2018 6:46 pm
Yes, see my earlier response - something was missing in the compiler settings. Please try the next one:
PostPosted: Sat Nov 17, 2018 6:48 pm
Stereo Tool 9.12 BETA007
Windows stand alone: https://www.stereotool.com/download/ste ... 12-007.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 12-007.exe
VST 2: http://www.stereotool.com/download/vst_ ... 12-007.dll
VST 3: http://www.stereotool.com/download/vst_ ... 2-007.vst3 DOES NOT WORK ON MY END SO PROBABLY BROKEN
VST 2: https://www.stereotool.com/download/vst ... 12-007.dll
VST 3: https://www.stereotool.com/download/vst ... 2-007.vst3
  • VST3 64 bit plugin fixed (32 is probably still broken)
  • VST3 plugin
  • No PIN EWS
  • RDS AF method B
  • Hanegraaff
  • AAX plugin
  • Brian, NAB
  • VST for DJB
  • Test sound card
  • Fake stereo idea
  • Cntrct IN
  • RDS: RT end at \n
PostPosted: Sun Nov 18, 2018 3:35 am
Hi Hans
Yes - correct, but the error code did not come up immediately. I was at the computer for around 30-60 seconds after going into bypass, got called away (work commitment) and came back 2-3 hrs later with the error showing.
Today with BETA006 I have had the following come up...
This was with ST in processing mode but no audio (hence processing) occurring.
Ross
