Post new topic  Reply to topic  [ 155 posts ]  Go to page Previous 1 2 3 4 516 Next
PostPosted: Fri Oct 27, 2017 4:10 pm
Screenshot for the next beta...
Next beta has Telescope??? Is this the Milky way ?? :P :P :P
PostPosted: Fri Oct 27, 2017 10:12 pm
:D now you can see mars, and saturnus in the next beta :lol: .
unnecessary if you ask me ;)
Look ahead has no priority in my opinion, ;)
Garbage in is Garbage out !
PostPosted: Fri Oct 27, 2017 10:59 pm
Hi Hans, got an exception error while switching on Auto EQ, after update from 852 to 854-004 Standalone
Win7-64, AMD 4 core
After switching off Low CPU, no error occurred
PostPosted: Fri Oct 27, 2017 11:23 pm
@parelduiker: Lookahead is already there and has been for quite a bit now... See Clipper -> Use limiting instead. You might need to tweak the settings, I haven't *really* gone far with that. But I heard from multiple people that they prefer the sound over the clipper.
PostPosted: Fri Oct 27, 2017 11:48 pm
Yes, to believe everyone right away, that's a big mistake!, so steretool have not gotten better But Hans Sorry I have not taken you seriously for so long
Input, good input you do not do anything , do you know those stream encoders? ;) accept things from people here who do not know what they are doing.
that's why I replaced stereotool for something better ;
Congratulations and greet them at Telos :D
@Wunjo: I think I found the cause... too aggressive optimization. Not 100% sure, but I hope that the next build will work.
PostPosted: Sat Oct 28, 2017 12:03 am
@parelduiker: For clarity, the effect was small, and definitely doesn't affect the amount of bass or codec artifacts. And I've also heard from other people that they prefer the sound of the clipper. But it has been there for months now. Adding streaming is high (but not yet on top) on my todo list.
PostPosted: Sat Oct 28, 2017 9:11 pm
Stereo Tool 8.54 BETA006
Windows stand alone: http://www.stereotool.com/download/ster ... 54-006.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 54-006.exe
VST: http://www.stereotool.com/download/vst_ ... 54-006.dll
- *Probably* fixed crash reported by Wunjo (CPU related, so I can't easily test it).
- Combined and reorganized Compressor calls for better cache behavior and fewer separate threading calls.
CPU load with identical settings: 6.7% before combining threads, 6.5% after, 6.4% after improving cache.
- Omnia.9: Clean up L-R area when AutoPilot is active -> L-R should not even be demodulated in that mode.
- Optimize Peak mode as well? -> No, but Average is possible (and done now).
- Add goniometer More places?
- Finished optimizing performance Auto EQ etc. DONE, 9.5 times faster than in version 8.52!
- Finished optimizing performance of AGC
- Optimized performance of Multiband 1, Multiband 2 and Singleband in RMS mode (factor 3).
- Buffer issue Triple
- SCA was broken - only for threads > 1
- Gray screen Wolf
- Optimized Auto EQ and new AGC performance (partially done) -> Output can be slightly different with 'Low CPU' enabled (possibly even better!)
- Added MagicRDS remoting support (Pira program)
- Auto EQ was missing in main page
- Increase NAN detection thresholds (test with new AGC with insane input levels)
- Omnia.9 return clipped audio via callback
- Omnia.9 logging remove time and \n
- Scheduler killed new AGC setting!
- MicroMPX decoder web interface could hang on right click on tray icon
- Buffer issue Generic plugin - needs to be tested.
- SST increased contrast
- SST wrong word in MicroMPX settings
- SHEETS
- Add Goniometer level controls
- Check MB1 Digital mode, reported to not work anymore
- RMS compressor mode fails in 8.53??? Just dies, no more compression, but audio output and limiters still there. (Possibly fixed, waiting for feedback)
- SST installer
- Check compressor levels further
- Would a times 32 version be useful? (Or at least for ARM-based?)
- Omnia.9: Give more output values for smoother meters
- WatchCat website
- Set maximum to L-R asymmetry?
- One bass page
- New bass effect
- Revisit new Hard Limit / Final Limiter with Matt
- Report of Linux Jack version crashing - since 8.52
- Talk to chip
- 2 jaar
- Fardau
- Remote control via web interface doesn't work anymore for some people due to SID.
- -24 dB side chain range?
- Dummy data sturen om initialisatie te doen voor geluidskaart openen.
- 2nd AGC with higher threshold for voice tracks
- Bigger font on 4K screens
PostPosted: Sat Oct 28, 2017 10:35 pm
Multiband1 in digital mode has broken. In analog mode it works correctly. Win10 stand alone 64bit
beta004 was OK.
PostPosted: Sat Oct 28, 2017 10:54 pm
So agree on this one. That stream encoders thing, didn't I give a lot of idea's and stories about that one?
Veghel, we have a problem!
