Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2 3
PostPosted: Mon Jul 02, 2012 9:35 am
that's why there were some noises and the rds wasn't working good.
where i can disable that Left and Right tones?
how can i check that my transmitter is sending 75kHz deviation onAir?
(almost finished configuring :-) )
PostPosted: Sun Sep 16, 2012 9:33 am
Hello,
Yesterday i had a try with stereotool on a system wich i normaly build for BREAKAWAY.
I installed ST (latest beta version 6.32 0012) an configured everything.
Used it to generate stereo+rds subcarriers, just like i do on BBP
It performed like it should be, untill i talked trough the microphone...
The latency is undoable for live presentation.
This is not the case with breakaway Broadcast
I have tryed lower quality and buffer size to 32ms (lower latency caused an muted output) but still to mutch latency.
Also disabeled the declipper.
Does anyone have tips ?
regards,
Jeroen.
PostPosted: Sun Sep 16, 2012 9:50 am
- Did you set the latency to 512 samples?
- Did you enable ASIO?
- Make sure that ST is running at the highest priority (sound cards window), and reduce the buffer size to around 4 ms (I think).
This will give you a total latency of 17 ms, which - afaik - is identical to that of Breakaway.
