Post new topic  Reply to topic  [ 44 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Sat Jan 28, 2017 2:17 pm
Hi all,
Windows stand alone: http://www.stereotool.com/download/ster ... 21-010.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 21-010.exe
VST: http://www.stereotool.com/download/vst_ ... 21-010.dll
- SST: Text upside down, direction of some controls flipped. KOEK - OHW
- Make Pi version build again (something broke, might have been a fluke)
- 32 vs 64 bit 'error'?
- VLC potential crash when switching between streams fixed.
- Decide FB^2 mode -> Seems to be a keeper, default value?
- LW build
- Test Compressor2 sound and CPU load -> Nearly identical even after adding FB^2 (1.4% higher)
- Fix these: Compressor2.cpp(1132,3): warning #13379: was not vectorized with "simd", Compressor2.cpp(1139,3): warning #13379: was not vectorized with "simd"
- Make Windows versions build again
- NAB whitepaper
- 1 channel audio processing was broken in 8.20.
- More-than-2 channel audio processing was broken in 8.20 due to what appears to be a compiler bug.
- SST: Figure out way to show ms values in sliders with negative direction Wait for feedback, maybe in Hz or / in front of it?
- SST: Attack Multiplier: Remove the x values? Maybe 0 in center, -10 to +10? (* and / would make more sense!) Wait for feedback, maybe switch x and /
- SST: Skype call with Jim about names.
- Make Pi image
- Time zone set & gmtime() / localtime() issue in Windows. Get it to Leif
- MicroMPX: Improve pilot merge after drop when using slightly wrong frequency. (How important is this?) -> Not a problem
- SST: Disable 'MULTICORE' for latency 128, maybe also 256. What about LQLL -> Also off What about 512?
- SST: More Skype with Jim
- Possibly add code 0 for FM 87.5 in the AF list. Seems to be supported by some receivers.
- MicroMPX: Check Stokkemask compliance on drops -> Seems ok! Still better to filter! MATHIJS
- BS412: Singleband compressor was placed after BS412, should be before - fixed.
- Add glowing yellow line around SST tray icon, to make it more visible.
- WatchCat reset, test that output level is 100%
- WatchCat license dingen.
- WatchCat font size
- SST: Reset settings when loading a new preset, now it keeps the current settings - that's bad for new settings!
- Stereo Tool: Add info to .sts files to allow importing them in Omnia SST.
- SST: Improved Stereo Tool settings import
- Make FF and 100% FB^2 behave the same in speeds.
- Perfect Declipper crash
- UECP recv hangs after connection close - web server too??? When do I disconnect? http://tldp.org/HOWTO/TCP-Keepalive-HOWTO/overview.html -> Moved things to a separate thread, and if a new connection comes in the old one gets closed, instead of waiting for it infinitely and ignoring the new one.
- Someone reported that their ASIO card isn't visible in 8.20. It's there in 8.14. Digigram VX222v2. Maybe 32 vs 64 bit issue? -> Looks like it, it works in 32 bit Stereo Tool 8.20.- Build version with only FB^2 mode, without insane CPU load
- ACR Stereo crackling
- Cracks and overshoots Wes Keene, caused by a bug in RDS quadrature mode which strangely never caused issues before
- SST preset load stops server KOEK - OHW
- SST after preset load, some settings (Clipper drive among others) can get reset by just clicking. Check if fixed when the preset load stop bug is fixed. KOEK - OHW
- Import FM Settings" doesn't Import the BS.412- Settings in 8.20 (Robert Sack) --> On purpose, but probably not very clear from how the GUI is laid out.
- MAC version VST 64 doesn't work on some systems - Fixed for OcenAudio
- GiP create samples or presets: Loudness with limiting seems better, gain riding, fast vs slow control vs low drive When I Grow Up
- Declipper weird effect on voices - change "Stop declipping if texture did not increase above" value (more testing with more material needed!)
- MAC version VST 64 doesn't work in Audio Hijack
- GiP code - add L/R input
- GiP recordings & demo set
- Spoedcursus audio
- Opdrachtdefinitie - wat precies willen we
- SST: Encrypted uMPX license MATHIJS
- AGC weird effect on voices with Windowing - Check Wolf Stahl's report
- Check RS BS412 settings
- SST build
- SST: Multiple MicroMPX output IP addresses and ports in web GUI!!! KOEK - OHW
- SST: Shane manual
- SST: Shane's Lynx card analysis.
- SST: Change something with saving presets/loading presets so you can't accidentally load sound card settings etc. (DANGEROUS, can take you off the air!) "In a processing preset menu, you probably should only load processing files. Other omnia's have separate I/O presets. EVERYTHING is dangerous. HIDE it when in PROCESSING/CLEANUP. Save and recall system stuff separately?"
- SST: Help with ? in top menu which makes things clickable.
- SST: Add built-in help
- SST interface in uMPX command line version
- PortAudio MATHIJS
- Framework Radboud MATHIJS
- Entering license in Mac version VST crashes MATHIJS
- WatchCat close issue on Mac MATHIJS
- Add buffer underrun warning - auto detect lowest possible latency??
- Maybe add common logging?
- "Stuck" 1 dB difference multiband compressor mode before AGC
- Thread priority overview
- Continue with AA Ratio, ARS Mode, Max Ratio, check which are needed and adjust GUI to make everything fit again.
PostPosted: Mon Jan 30, 2017 3:38 pm
Hello, Hans.
Would you please take a look at positive peak clipping for AM?
In recent versions, I've had a transmitter reach near 140% positive, even though the peak slider is between 100% and 105%.
Last night, I rolled the processor back to version 8.01, beta 001, and positive peak control returned. Also, without changing anything, negative levels were something like 1/2 to 3/4 dB lower, though that was easily adjusted back.
In this application, I'm using a USB audio interface with no ASIO (Henry Engineering "USB Matchbox II").
Thanks.
-Jack
I don't see this with the latest version. Could you check it again, and if it still fails, send me your settings?
PostPosted: Mon Jan 30, 2017 4:14 pm
New MAC VST 64 bit version - there was a non-ASCII8 character in the parameter list that could cause some programs (OcenAudio, great program btw!) to refuse to load it. http://www.stereotool.com/download/ster ... 11.vst.zip
PostPosted: Tue Jan 31, 2017 12:14 pm
I can't wait until a VST plugin is working in Nicecast on Mac. Do you think this is possible in the short term?
Even better would be a streaming broadcast tool inside of Stereo Tool ...
Regards,
Larry
PostPosted: Tue Jan 31, 2017 8:46 pm
Regards,
Larry
It doesn't work in that? Then there must be a bug somewhere... do you have an error message?
PostPosted: Tue Jan 31, 2017 11:31 pm
Regards,
Larry
It is not possible to activate the plug-in. The 64 bit version is not visible. The 32 bit version is visible, but I can not activate it. See screenshots.
File comment: Screenshot 1
File comment: Screenshot 2
PostPosted: Tue Jan 31, 2017 11:44 pm
We'll have to check why. The OcenAudio issue was pretty simple (we had a µ character in one of the parameters, turned out that OcenAudio wrote that to an XML file and then it was unable to parse the file that it write itself because it didn't know which character encoding was used). So it can be something silly like that. (I'm not even sure if I should call that a bug in Stereo Tool or in OcenAudio).
PostPosted: Thu Feb 02, 2017 10:31 am
Hi all,
Windows stand alone: http://www.stereotool.com/download/ster ... 21-012.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 21-012.exe
VST: http://www.stereotool.com/download/vst_ ... 21-012.dll
- Continue with AA Ratio, ARS Mode, Max Ratio ENABLED NOW FOR TESTING ONLY, WARNING: CPU LOAD IS INSANELY HIGH IN THIS VERSION!!!!!!!!
- LW build
- NAB whitepaper
- Make Pi image
- MAC version VST 64 doesn't work in Audio Hijack and Nicecast -> No errors logged, it just doesn't open it (even on explicit loads) -> ask Rogue Amouba for info.
- Figure out new value for "Stop declipping if texture did not increase above"
- Spoedcursus audio
- SST build
- SST: Shane manual
- SST: Add built-in help BUSY
- PortAudio
PostPosted: Fri Feb 03, 2017 8:26 pm
Thanks for the release of the final version!
First bug without even listening: all EQs have the frequency 6299 Hz changed to 6298 Hz, causing a funny peak there, because presets obviously still try to load a value for the old frequency but the new (unset) one is actually used.
PostPosted: Fri Feb 03, 2017 8:33 pm
Ow! Crap! Then I must have fixed that in the wrong direction. All presets that I saved in debug mode had a different value there than in release mode. Ugh...
