Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: Re: Stereo Tool 8.12
PostPosted: Sun Nov 06, 2016 11:56 pm
Don't know why but affinities settings is not saving correctly.
Example:
In Main 1 and Main 2 (with 2 threads), under Processing - CPU core tab, if set CORE 3, after a software restart it will be ANY again...
PostPosted: Mon Nov 07, 2016 2:37 pm
Wavosaur no longer loads the VST plugin (we use it for batch processing), I also have experienced sometimes Foobar with Stereotool as fixed VST loaded (we use it for offline fine tuning the .sts) when started no longer processes audio.
Just tried Wavosaur here and it works fine (both 32 and 64 bit). Can you give me more info of what happens exactly? Do you get an error message?
PostPosted: Mon Nov 07, 2016 2:39 pm
Example:
I see it gets overwritten by the LQLL CPU core affinity settings.
Fixed for the next beta.
PostPosted: Mon Nov 07, 2016 8:50 pm
Bug in the FM Soundcard Calibration section using the DSP version. When enabled the audio output level drops really low. when disabled the level comes back to normal. This behavior does not exist in Stereo Tool 8.00.
I know this section has been superseded by FM tilt but I still use this to correct the frequency response of my transmitter and to adjust the RDS to Stereo Poilet phase.
PostPosted: Tue Nov 08, 2016 7:11 am
Not only the DSP version, it is in standalone too.
PostPosted: Wed Nov 09, 2016 1:21 pm
Cause found and solved (next beta).
PostPosted: Thu Nov 10, 2016 11:43 am
Hi Hanz,
With version 8.12 on one transmitter site, I have small perturbations in the sound (like a small scratch may be every 10 sec). When I rollback to 8.00, no problem.
CPU: Intel Xeon W3540 @2.93GHz 8 cores (cpu load with 8.00 20% for all cores and 56% on 2 cores)
Sound Card: input: VB-Audio Virtual Cable / FM Output: ESI Julia Asio Chan1
I have try with 4 or 6 threads, same problem on 8.12
An idea ?
Thanks
PostPosted: Thu Nov 10, 2016 1:24 pm
Hi Hanz,
An idea ?
Thanks
Since it's at the transmitter site I suppose you can't install 8.12 on it again and give me TeamViewer access?
Can you send me your settings so I can check if I see something weird here? I need all the settings, including sound card and CPU.
My only guess right now is that you have set the ASIO buffer size to the absolute minimum to reduce latency. But... I did tests here and that should actually work better on 8.12 than on 8.00. But I might have missed something. There are more people who are complaining about similar things.
Edit: I think I just found something suspicious...
Edit #2: We have an O, we have an O, we have a P, we have an S... OOPS!
PostPosted: Thu Nov 10, 2016 1:41 pm
We`ll have a F, we`ll have an I, we`ll have an X. We`ll have a FIX :)
PostPosted: Thu Nov 10, 2016 2:02 pm
Thanks for your answer,
I have email you my stereo_tool.ini
I don't remerber have changed default buffer size for asio.
PS: Your Edit2 tell us that you find something ? :-)
Regards
Stef
