Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2 3
PostPosted: Tue Oct 25, 2016 3:40 pm
Found a bug. WatchCat seems to crash every time after importing a bunch of (.wav) files. These are my settings:
[General]
MoveInputFilesAfterProcessing=false
RemoveInputFilesAfterProcessing=true
ReallyRemoveInputFilesAfterProcessing=123456789
[MainWindow]
size=@Size(640 481)
pos=@Point(200 200)
[Monitoring]
WatchFolders=@Variant(\0\0\0\x1c\0\0\0\x1\0\0\0\x12\0\x43\0:\0/\0i\0m\0p\0o\0r\0t\0\0\0\x10\0\0\0\0\xff\xff\xff\xff\xff)
ReadExistingFilesOnAdd=true
[Outputs]
1\processing=false
1\presetFile=
1\encoding=0
1\compressionLevel=0
1\normalizationEnabled=true
1\normalizationMode=1
1\normalizationTarget="@Variant(\0\0\0\x87?5;\xef)"
1\outputDirectory=O:/import
size=1
[Processing]
MulticoreProcessing=false
NormaliseInput=false
[StereoTool]
License=
[Output]
OverWriteExistingFiles=false
The outputDirectory is a network share mapped as O-drive. The server is running Windows Server 2008 R2 Std.
PostPosted: Fri Oct 28, 2016 11:25 am
Long Time waiting for that !
Great !
PostPosted: Fri Jan 06, 2017 2:38 am
It has taken some time but there's a new version out! There are still a few issues remaining that need to be fixed, but this version should be very usable.
http://www.stereotool.com/download/Thim ... er_820.exe
This version is no longer only usable for audio files, you can now use scripting to process or normalize (R128!) audio in video's too. To be able to use the scripting you'll need a license, you can test it without a license but it will add some beep sounds. The version without scripting is free - except that you might need a Stereo Tool license if you use paid Stereo Tool options in your preset.
This version is still a beta, but I think it's nearly there now.
Known issues at this moment:
- R128 normalization: True Peak level might be off, because it doesn't overrule the 'Post Amp' setting yet. (Set it to 0.00 dB in your preset as a workaround).
- Settings should be reset on startup (before you select a preset), that doesn't happen.
- No error message shown when the license isn't accepted.
- Some fonts are too small on 4K screen
PostPosted: Fri Jan 06, 2017 7:04 am
Not Found
The requested URL /download/ThimeoWatchCat_64_installer-820.exe was not found on this server.
Same as the link of perfect declipper.
PostPosted: Fri Jan 06, 2017 8:58 am
It needs to be installer_820 not installer-820.
PostPosted: Fri Jan 06, 2017 10:06 am
Download link is fixed now.
PostPosted: Tue Jan 10, 2017 6:28 pm
Latest beta (basically a release candidate):
viewtopic.php?f=14&t=13433
