Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 1193 194 195 196 197213 Next
PostPosted: Mon Sep 26, 2011 4:45 pm
I have athlon II X2 240e.......
PostPosted: Mon Sep 26, 2011 9:15 pm
Can you send me preset, either by posting here or by sending it to me in PM, that you claim is low CPU usage?
PostPosted: Mon Sep 26, 2011 9:36 pm
@ Hans
Can AEHP be separate On and Off from ABDP ?
PostPosted: Mon Sep 26, 2011 10:46 pm
@ Hans
Not currently. Would have to write some extra code. Why? Is there any reason to turn ABDP off?
PostPosted: Mon Sep 26, 2011 10:47 pm
@ Hans
In the DSP version, both have their independent checkboxes... Are you saying that is different with VST or Stand-Alone, or are you saying that if you disable the bass protection the highs protection gets turned off too?
@Hans' response... I'm so confused... So, I'm going to go pick up brakes for my car... 8-)
PostPosted: Mon Sep 26, 2011 10:49 pm
hmm .. no :)
@Brain - I can tell you for Standalone. If you turn off ABDP, AEHP does not working.
PostPosted: Mon Sep 26, 2011 11:28 pm
I`m not saying that is low CPU usage
I told that these differences with GUI up and GUI to toolbar are not present in my machine ?! difference is about near 3-4% only ( not from 30 to 55% or like this )
Hope understand right ?
Btw I have a preset in "Preset share " section here in forum
You may download it and test .
PostPosted: Tue Sep 27, 2011 12:08 am
Since there are much more countries to be identified, some countries have to share the same code which does not permit unique identification.
PostPosted: Tue Sep 27, 2011 12:52 am
Ok i have some bug for you to fix :)
http://i.imgur.com/OrIpU.png
I get square waves on the input of stereo tool when i use a different sound card for input.
I have Marian Trace Alpha 1-2 for input and Juli@ Ch12 for output.
When i move around the taskmanager it changes the amount of added square waves.
It looks like the display problem i reported earlier, only now it's audible so yes it sounds horrible.
I'm beginning to think maybe problem is in the marian card, but i'm not sure.
PostPosted: Tue Sep 27, 2011 2:22 am
I have read a lot of conversation regarding CPU load and when is 6.20 going to be released.
Hans, please release it now. First, I am at beta 123. I download every version and install every one. There is no way to please everyone. I have been in commercial radio for a number of years. Without scopes attached to my pc, no one can hear any difference (trust me).
For the AMD folks, by Intel. AMD has had a lot of compatible issues. I am using ST on an Intel I5 4gb with winamp and the utilization is running about 20% wihile I am doing uploads through my VPN. Oh, I also have Outlook running on the same PC. I forgot, my MSN account is also running.
As a software developer for many years, it is time to make the cut and continue after that.
