Hans ,, I would be gradefull if u could make a very simple "tweak " for the RDS code of ST standalone.
Is it possible to NOT BROADCAST the PI CODE on RDS ?
( for exaple, if i leave the PI code blank ( now it is not possible , i know )
But, can you make this case ? If leave the PI CODE blank , to NOT broadcast PI CODE at all!
( In many cities, in many Countries , PI CODEs are like a meeeesss!!!!!!! , many stations have the same pi codes , e.t.c. )
( If i change my PI CODE ...then the competitive radiostation changes it again to take listeners from me on another location!! ) i am sick of it!
please
The RDS standard doesn't enable that
When I broadcast the PS text, I have to include a 16-bit number in it - leaving it empty would just mean broadcasting a PI code of 0 which would not help at all.
According to the standard, you should use FFFF in this case - but it depends on your receiver if it will still switch to other stations or not. And if everyone who only has a single frequency uses FFFF you can imagine the mess that that would cause.
Actually, if you send only your own frequency as AF (Alternative Frequency), radios should NOT switch to other frequencies. Again, this depends on the radio.
