Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 118 19 20 21 2243 Next
PostPosted: Tue Aug 16, 2016 6:25 am
Perhaps the best feature to go in ST in years. It makes all the difference in the world.
One of them. :)
I'm still voting for fixing/redoing something (Hans knows) within the control circuit of the "Digital" (multi-band/single-band) compressor, which would also improve Natural Dynamics detection (but that's eventually getting redone).
I've been working on a new update for the Minnesota presets, and it's just the "North" version that will continue from now on, simply as Minnesota. It's sounding better than ever in the testing so far. In general there's less range within the multiband, which removes some of the spectral balancing ability during extremes, but it also has less of the Digital mode compressor's inaccuracies (about half compared to what's public). It's considerably more open when it should be, but can still adapt extremely quickly (faster than you can hear) when it needs to. Currently working on stress-testing the new AGC settings.
It'll be the last public release of Minnesota until the Digital mode multiband is fixed/redone, at which point I can start working on the final version of it.
If that update effects Natural Dynamics, or when there's new dynamics detection being worked on for that, you can bet I'll be testing that and working on new settings for it.
PostPosted: Tue Aug 16, 2016 6:33 am
That's pretty much the point where I'm at, too, Jesse.
I've published 0.09 of ElevenHeaven to Hans and on FB. It is a pop preset and I think it's gone as far as it can.
I know Hans is working on some things we've all been requesting. When those are done, it will not be a drop in fix. I will have to completely rework my preset. That's a chore I will be more than happy to undertake. Until that time, I believe I've produced the best preset that can exist given the vision constraints I've placed on this preset.
I'm extremely happy with what we're able to produce thus far and very grateful to Hans for his excellent strides in this release.
PostPosted: Wed Aug 17, 2016 1:31 am
I'd like to thank Wes also for his preset which I have been testing since 0.07 on our little LPFM. We're 50/50 talk and a wide range of Christian music - everything from soft CCM to hymns to classical to Americana.
Seems to be a good all around preset to these ears.
PostPosted: Wed Aug 17, 2016 1:41 am
Thanks! I love the feedback. This was a fun exercise.
PostPosted: Wed Aug 17, 2016 6:26 am
Current Beta
Standalone Version
Windows 7 x64
PostPosted: Thu Aug 18, 2016 2:15 pm
[quote="Clipper"]
As above. Getting the same. It does restart but of course interrupts program.
PostPosted: Fri Aug 19, 2016 9:55 am
Hm, unfortunately it turns out that the exception address is inside an Intel library function - I have no way of seeing how it got there. Paul, did you have the same address? Does either of you have a way to reproduce this issue?
Edit: I have just found a bug that could cause something like this, but only on preset switching. I found another that could occur when no FM output was selected. Did you get this exception when changing settings or just when audio was running?
I will run a new build in about an hour with these 2 fixes.
PostPosted: Fri Aug 19, 2016 12:08 pm
For me all I did was start ST and that happened.
On restart it has never happened again.
C.
PostPosted: Sat Aug 20, 2016 8:55 am
Fixed:
- Add Declipper main view
Windows stand alone: http://www.stereotool.com/download/ster ... 01-021.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-021.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-021.dll
Known issues:
- Claimbigf failed once ("Claimbigf failed: In use!") -> Added extra checks, should warn if it happens again. I'm guessing it was triggered by some other bug.
- Make new separate Presets class
- Absolute Highs display broken. Only in HQ version. -> Weird only on Koek pc. Check tomorrow. Ah, only weird if there's real audio, not on background noise there. Maybe stereo effect? Still unable to reproduce on my pc...
- Add agc drive
- Generate UIDs and use link
- Password for login?
DONE:
- Gain works again
- Type IP in web site
Later:
- Run as a service
- Websockets? Later
PostPosted: Sat Aug 20, 2016 1:01 pm
Why i don`t see from where to set the Quality >100% ? My slider is still max 100% - Stand alone.
EDIT: Found exception error when i set AGC to 1.00:1 - it acts like turned OFF, but if DB style is enabled , it shows the error.
If i disable the DB style, i can close the exception window.
Edit2: Gate indicators in AGC main window are not working (not moving) like in the main ST window indicators(above scopes).
