Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 118 19 20 21 2259 Next
PostPosted: Sat Feb 20, 2016 2:58 pm
Thank you for the new version! The new setting options I find very good. Thus, the entire shrill sounds no longer appear in the result.
PostPosted: Sat Feb 20, 2016 3:12 pm
Strange sound when starting a song solved, thanks!
Btw, where can I find the AM Test tone setting?
PostPosted: Sat Feb 20, 2016 7:39 pm
Weeh! It took me almost an entire day staring at spectra to figure out how to fix them without getting the gritty distorted sound back from earlier versions. So, this version is the best so far I suppose? If so I can start finalising it. .
PostPosted: Sun Feb 21, 2016 12:18 pm
In my whole experimental examples everything went fine! I can well imagine that the problem was not easily solved. But you did a damn good job in the last few months! I'm concerned you could finalize it now.
PostPosted: Sun Feb 21, 2016 6:17 pm
In the stand-alone beta 34 I hear a very low level clicking coming from the composite clipper in the Advanced Clipper section. I can only hear it during quiet passages of music or if I reduce the input to a very low level. This with beta 34 only, previous betas did not have this.
J0HN II
PostPosted: Sun Feb 21, 2016 6:30 pm
Yup there are more reports of issues with 034. Must be caused by the performance optimizations that I did for the Raspberry Pi 2. Will check tomorrow!
PostPosted: Tue Feb 23, 2016 12:37 am
7.85 BETA036
Windows stand alone: http://www.stereotool.com/download/ster ... 85-036.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-036.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-036.dll
CHANGED:
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Fix crash in BETA036.
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?)
- Exciter: Add auto-adjust HPF frequency
- Voice protection in classic MB is broken. Check what changed. (Code should not have changed at all). - Hm, more has changed. Check in which version! -> Waiting for reply to question
- Add Polar stereo viewtopic.php?f=16&t=6233&p=33031#p33031
- MP3?
LATER:
- O skin
PostPosted: Tue Feb 23, 2016 12:52 am
Thanks as always Hans.
I always start off when a final is released I think "this is the final version I'll listen with, I won't play with the beta's"
And then before I know it, I'm downloading a new beta every day to test with!
Cheers,
Tim
PostPosted: Tue Feb 23, 2016 7:30 am
Hello, this colour change is intentional?
PostPosted: Tue Feb 23, 2016 11:10 am
When loading a (stock) preset, stereotool crashes in this beta. (tested standalone version)
The Power of Sound
